Special DBA 4000 & 5000 Series Sport Rotors
Old Mar 2, 2011 | 06:58 PM
JEBperformance's Avatar
JEBperformance
Thermal Stability Profiling
4000 and 5000 series brake rotors can handle extreme applications thanks to Thermal Stability Profiling or TSP.
This unique process provides greater thermal stability than standard street discs. TSP enhances the micro structure of the disc rotor for performance applications.
Greater thermal stability allows your discs to take more heat, making them more stable under heavy braking for longer. TSP also means improved brake pad and disc rotor life, and delayed brake fade.
DBA’s Kangaroo Paw
delivers significantly improved braking performance under all conditions to make you safer than ever before.
The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc brake rotors.
So what makes it work so well? To answer this, let’s look at a car’s braking system. This system is critical in terms of vehicle safety and performance. Being able to stop reliably, time after time, under heavy braking conditions can mean life or death.
Every time the brakes are used massive pressure is built up through the braking system. The force your foot applies at the brake pedal is multiplied many times at the disc rotors, creating friction and extreme heat.
The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘cooling vanes’. However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to allow an unwanted ballooning effect.
Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application – without this ballooning.
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. The pillars create greater strength, reliability, and a more efficient cooling system. Greater surface area means more rapid heat dissipation.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
That’s why the Kangaroo Paw system is so effective.
Available across a range of products for most popular vehicles, it’s the greatest advance in brake rotor design for decades – guaranteed!
The 5000 series rotors are designed for the serious street driver. These 2-piece ultra-high performance rotors feature aerospace grade materials (
Alumalite) for added thermal (heat) protection to your vehicle's wheel bearings, by providing greater resistance to distorion as it allows the disc to expand uniformly.
For the serious driver, the 5000 series 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicle's wheel bearings.
The Alumalite centre / hat / bell is made from light-weight 6061-T6 aircraft aluminum material (re-usable).
The aircraft-grade aluminum centre
provides greater resistance to distortion as it allows the disc to expand uniformly.
The 5000 series rotors also feature NAS (National Aerospace Standard) bolts and lock nuts.
<iframe title="YouTube video player" src="http://www.youtube.com/embed/8PzWFn6lGBs?rel=0" allowfullscreen="" width="425" frameborder="0" height="349"></iframe>
4000 and 5000 series rotors also incorporate DBA's Thermo-Graphic heat paint marking which change colour at specific temperature thresholds.
By monitoring the markings, drivers can check their braking performance quickly and easily.
Disk Brake Australia Rotors are sold separate. Either left or right rotors.
2008+ G37 Sport DBA 4000 Series Slotted Rotor
42314SL Front Left MSRP $350
42314SR Front Right MSRP $350
42315SL Rear Left MSRP $245
42315SR Rear Right MSRP $245
2008+ G37 Sport DBA 4000 Series Drilled & Slotted Rotor
42314XS Front MSRP $371 (must order 2 for front left and right)
42315XS Rear MSRP $266 (must order 2 for front left and right)
2008+ G37 Sport DBA 5000 Series two piece Rotors
52314BLKSL Slotted Front Left Rotor MSRP $504
52314BLKSR Slotted front Right Rotor MSRP $504
52314BLKXS Front Drilled/Slotted Rotor MSRP $504 (must order 2 for front left and right)
Thank you for ordering MADE IN AUSTRALIA DBA Rotors from JEB Performance.
Old Mar 2, 2011 | 07:09 PM
dal1307's Avatar
dal1307
Holy Crap! This is a good deal. I wish that I had not already bought a set of these. You would have saved me $300!
Old Mar 2, 2011 | 08:16 PM
joo030879's Avatar
joo030879
How do you like them? care to share. Thank you in advance.
Old Mar 2, 2011 | 08:21 PM
dal1307's Avatar
dal1307
I will in a couple of weeks after they are installed. I will post up my impressions. All I can say at this point is that they look nice!
Old Mar 3, 2011 | 02:49 AM
G35_FTMFW's Avatar
G35_FTMFW
Are these replacement rotors for the Sport brakes??
Old Mar 3, 2011 | 02:56 AM
Staples's Avatar
Staples
Wow that's a GREAT price on both the 4000 and 5000s!
Old Mar 3, 2011 | 10:39 AM
dal1307's Avatar
dal1307
I was assuming that these were for the Sport brakes when I read the OP but that is a good question. The 5000s are 2 piece but I am assuming that this price includes the hat and rotor.
Old Mar 3, 2011 | 11:23 PM
JEBperformance
With JEB or any other vendor from MYG37.com there is no need to shop around. You will get best price.
Good Luck
They will only fit Sport Akebono BBK's.
Thank you we try our best to bring the best for much much less.
Yes they include top hats as well. I would like to add, all rotors in stock are black top hats. If you prefer any different color please PM us so we can special order @ same price.
Old Mar 3, 2011 | 11:44 PM
huwee06's Avatar
huwee06
do you have 2pc rears? I want to buy fr&rr are they still availible? Also what color is the top hat appreciate it!
Old Mar 3, 2011 | 11:50 PM
dal1307's Avatar
dal1307
Old Mar 4, 2011 | 12:11 AM
JEBperformance
Sorry DBA only makes 2pc front rotors. Consider 2 pc front with 1pc rear rotors.
All in stock from JEB Performance are black top hats. However other color Gold can be specially ordered. @ same low price.
Old Mar 4, 2011 | 12:19 AM
dal1307's Avatar
dal1307
Anyone considering these rotors should jump on this deal. I looked for a month and this is by far the best price around.
Old Mar 4, 2011 | 06:44 PM
JEBperformance
Best mod comes when we really thirst for performance. Please make sure to use your current rotors as much as you can. Before changing. Our OEM is just as good on the street.
Old Mar 7, 2011 | 01:31 PM
JEBperformance
BBK performance for your Sport Akebono Brakes. For much less. 2pc rotors separately sold only from DBA.
Old Mar 8, 2011 | 01:51 PM
JEBperformance
