Special DBA 4000 & 5000 Series Sport Rotors
Old Apr 7, 2011 | 02:32 PM
  #31
Viper62382's Avatar
Viper62382
How long would it take to get the Gold hat 2pc rotors?
Old Apr 8, 2011 | 12:04 PM
  #32
JEBperformance's Avatar
JEBperformance
Thermal Stability Profiling
4000 and 5000 series brake rotors can handle extreme applications thanks to Thermal Stability Profiling or TSP.
This unique process provides greater thermal stability than standard street discs. TSP enhances the micro structure of the disc rotor for performance applications.
Greater thermal stability allows your discs to take more heat, making them more stable under heavy braking for longer. TSP also means improved brake pad and disc rotor life, and delayed brake fade.
DBA’s Kangaroo Paw
delivers significantly improved braking performance under all conditions to make you safer than ever before.
The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc brake rotors.
So what makes it work so well? To answer this, let’s look at a car’s braking system. This system is critical in terms of vehicle safety and performance. Being able to stop reliably, time after time, under heavy braking conditions can mean life or death.
Every time the brakes are used massive pressure is built up through the braking system. The force your foot applies at the brake pedal is multiplied many times at the disc rotors, creating friction and extreme heat.
The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘cooling vanes’. However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to allow an unwanted ballooning effect.
Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application – without this ballooning.
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. The pillars create greater strength, reliability, and a more efficient cooling system. Greater surface area means more rapid heat dissipation.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
That’s why the Kangaroo Paw system is so effective.
Available across a range of products for most popular vehicles, it’s the greatest advance in brake rotor design for decades – guaranteed!
The 5000 series rotors are designed for the serious street driver. These 2-piece ultra-high performance rotors feature aerospace grade materials (
Alumalite) for added thermal (heat) protection to your vehicle's wheel bearings, by providing greater resistance to distorion as it allows the disc to expand uniformly.
For the serious driver, the 5000 series 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicle's wheel bearings.
The Alumalite centre / hat / bell is made from light-weight 6061-T6 aircraft aluminum material (re-usable).
The aircraft-grade aluminum centre
provides greater resistance to distortion as it allows the disc to expand uniformly.
The 5000 series rotors also feature NAS (National Aerospace Standard) bolts and lock nuts.
<iframe title="YouTube video player" src="http://www.youtube.com/embed/8PzWFn6lGBs?rel=0" allowfullscreen="" width="425" frameborder="0" height="349"></iframe>
4000 and 5000 series rotors also incorporate DBA's Thermo-Graphic heat paint marking which change colour at specific temperature thresholds.
By monitoring the markings, drivers can check their braking performance quickly and easily.
Disk Brake Australia Rotors are sold separate. Either left or right rotors.
2008+ G37 Sport DBA 4000 Series Slotted Rotor
42314SL Front Left MSRP $350
42314SR Front Right MSRP $350
42315SL Rear Left MSRP $245
42315SR Rear Right MSRP $245
2008+ G37 Sport DBA 4000 Series Drilled & Slotted Rotor
42314XS Front MSRP $371 (must order 2 for front left and right)
42315XS Rear MSRP $266 (must order 2 for front left and right)
2008+ G37 Sport DBA 5000 Series two piece Rotors
52314BLKSL Slotted Front Left Rotor MSRP $504
52314BLKSR Slotted front Right Rotor MSRP $504
52314BLKXS Front Drilled/Slotted Rotor MSRP $504 (must order 2 for front left and right)
Thank you for ordering MADE IN AUSTRALIA DBA Rotors from JEB Performance.
Old Apr 8, 2011 | 12:05 PM
  #33
JEBperformance
Confirmed in stock with DBA, so a week to get to us. And another week to be shipped. Thank you.
Old Apr 11, 2011 | 02:31 PM
  #34
JEBperformance
back to top
Old Apr 15, 2011 | 12:32 AM
  #35
JEBperformance
A red top hat is not an option at the moment
Old Apr 19, 2011 | 08:13 PM
  #36
JEBperformance
New lower price
Old Apr 21, 2011 | 02:26 PM
  #37
JEBperformance
5000 Series replacement rotors can be ordered without the top hats
Old Apr 23, 2011 | 01:08 PM
  #38
VossenG37S's Avatar
VossenG37S
I know you pmd me b4 about this lol sorry for the second request but I'm trying to figure out what's best I see 2pc rotors 4000 and 5000 dunno what to get! I def want slot and drilled here I's what I need ! And a new lower price? Hmm I should order today.
IM actually I'n the need of rotors please give me a package deal shipped to 33020 for
Rotors crossed drilled and slotted .
SS Lines
Pads
Fluid
This I's for a 08 S Coupe it's a DD !!!! Please give me some recomendTions on parts thanks
Old Apr 23, 2011 | 01:29 PM
  #39
Viper62382's Avatar
Viper62382
Wheres the new lower price? I still see $500 and $720 respectively
Old Apr 26, 2011 | 10:53 PM
  #40
JEBperformance
SS Lines
Pads
Fluid
Package deal sent thank you
Old Apr 28, 2011 | 08:42 PM
  #41
JEBperformance
DBA Kangaroo Paw Disc Rotor Ventilation Design
Old May 3, 2011 | 01:26 PM
  #42
JEBperformance
Tuesday BUMP
Old May 6, 2011 | 01:16 PM
  #43
JEBperformance
All of us @ JEB wishes you a wonderful Weekend.
Old May 12, 2011 | 10:59 PM
  #44
JEBperformance
Thursday Night BUMP
Old May 18, 2011 | 05:04 PM
  #45
JEBperformance
DBA’s Kangaroo Paw
