++++ Rotora BBK BLOWOUT!! ++++
Old Jul 9, 2010 | 05:55 PM
THMotorsports's Avatar
THMotorsports
Guys,
Rotora is blowing out some big brake kits right now. I want to pass the savings on to you guys.
Here is what is available.
PN: RBK073.11
Specs: 4 Piston Front Caliper
Rotor Size: 330x30 - 2 Piece
Available Caliper Color: Red or Metallic Blue
Available Rotor Style: Slotted or Drilled & Slotted
MSRP: $2095
Your price: Please PM Me...its literally amazing. Call if you'd like as well: 1-800-959-0145
INCLUDES
Rotora billet aluminum alloy 4-piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
Rotora billet aluminum hat with “floating” disc assembly to reduce heat related stress and unsprung weight.
Rotora two piece heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs up to 16” (405mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
OPTIONAL:
Standard Caliper Color: Red or Metallic Blue.
Disc Type: Slotted, or Drilled & Slotted oversize discs. (For more severe applications, slotted is preferred. For street and light track use, plain OEM or drilled & slotted is acceptable).
Old Jul 12, 2010 | 03:51 PM
THMotorsports
PM's sent, welcome back from the weekend!
Old Jul 12, 2010 | 04:12 PM
jarborn1's Avatar
jarborn1
Could you PM me the price shipped to 10801??
Thank you
Old Jul 13, 2010 | 12:01 PM
THMotorsports
Hello everybody
Old Jul 14, 2010 | 04:43 PM
THMotorsports
Hump day w00t!
04G35NYC
Dec 24, 2015 01:00 AM
alxmlr789
Dec 1, 2015 03:55 AM
ck1109
Oct 15, 2015 11:06 PM
VIVID
Sep 27, 2015 09:45 AM
GFTW
Sep 19, 2015 03:52 PM
