Coilover sale TEIN, HKS AND KW AT FIFARACING
Old Jun 3, 2010 | 03:52 PM
FIFA RACING's Avatar
FIFA RACING
Coilover and lowering spring TEIN, Progress, HKS, Eibach, KW, ect
KW Variant 3 Coilover Kit Infiniti G37 Coupe 07+
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by KW engineers.
Features
  • Independently adjustable damping technology -rebound and compression damping
  • inox-line stainless steel technology at no extra charge
  • Individual height adjustment
  • German TUEV-tested adjustment parameters
  • High-quality components for long life
  • Comprehensive documentation for ease of use
  • Infinitely adjustable rebound damping
  • 14- level adjustable compression damping
  • Unique, independently functioning damping power adjustment
  • Lowering Adjustment ranges in mm, Front: 20-45 Rear: 0-45
  • Lowering Adjustment ranges in inches, Front: 0.8-1.8 Rear: 0.2-1.8
  • Springrates in Lbs/Inch, Front: Progressive Rear: Progressive
In stock and ready to ship!
WE GUARANTEE THE LOWEST PRICE ON ALL PRODUCTS LISTED ON OUR WEB SITE!
IF YOU CAN FIND A LOWER ADVERTISED PRICE FROM ANYWHERE PLEASE EMAIL US AND WE WILL MATCH THE VERIFIABLE PRICE!
Pm or calls us for price!
you can also chat whit us or email us at
Sale@fifaracing.com
WWW.FIFARACING.COM
Email
Sale@fifaracing.com
Toll Free: 1-888-553-FIFA
Old Jun 3, 2010 | 05:33 PM
FIFA RACING
Tein Type Flex Coilovers Infiniti G37 Coupe V36 08+
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. Tein has incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
Additional Features:
- Steel Construction
- Twin Tube internal construction
- Ride Height adjustable via threaded body and spring seats
- 16 way adjustable dampers, compression and rebound combined
- Pillow ball upper mounts for increased steering feel
- Upper camber adjustment on front for strut type vehicles
- Larger piston diameter for strut type front and rear (22mm)
- EDFC (Electronic Damping Force Controller) compatible
- Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
- 1-year Manufacturers Defect Warranty
Contents of Damper Kit:
-Adjustable Shock Absorber x 4
-Bump Rubber x 4
-Main Spring x 4
-Hook Spanner x 2
-Some applications include helper springs
-Dust Cover x 4
-Pillow ball Upper Mount x 4
- Instruction Manual x 1
-Lower Spring Seat x 4
-Sticker Sheet x 1
-Seat Lock x 12
Ride Height:
Front: -1.8"
Rear: -1.5"
Spring Rate:
Front: 783 lbs/in
Rear: 671 lbs/in
you can also chat whit us or email us at Sale@fifaracing.com
www.FIFARACING.COM
Email Sale@fifaracing.com
Old Jun 4, 2010 | 03:04 PM
FIFA RACING
Tein S.Tech Lowering Spring Infiniti G37 Coupe 08+
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
  • Chrome Vanadium SAE9254V Construction
  • Progressive Spring Rate Design
  • Includes Silencer Rubber on certain applications
  • Green Powder Coat Finish
  • Developed to be used in conjunction with OEM or OEM replacement dampers
  • 1-year Manufacturers Defect and Sag Warranty (Covers over 5mm sag, breakage, deformity, and noise. Does not cover powder coat finish and rusting.)
Contents of Spring Kit:
  • Individual Springs x 4
  • Main Spring x 4
  • Some applications include TEIN Silencer Rubbers
  • Warranty Information and Bump Stop Reference Guide
  • 2 TEIN Decals
Ride Height:
Front: -2.1"
Rear: -1.9"
Spring Rate:
Front: 358 lbs/in
Rear: 291 lbs/in
www.FIFARACING.COM
Old Jun 7, 2010 | 11:16 AM
FIFA RACING
Morning Bump!
Old Jun 9, 2010 | 05:30 PM
FIFA RACING
Evening Bump!
Old Jun 10, 2010 | 05:39 PM
FIFA RACING
Evening Bump!
Old Jun 10, 2010 | 06:27 PM
VossenG37S's Avatar
VossenG37S
KWV3 shipped to 33130 please for my 08 G37S coupe.
Old Jun 11, 2010 | 09:48 AM
FIFA RACING
PM Sent!
Old Jun 14, 2010 | 05:16 PM
FIFA RACING
Evening Bump!
Old Aug 9, 2010 | 07:42 PM
Obvis07's Avatar
Obvis07
pm me for the v3 and tein shipped to 92602
Old Aug 9, 2010 | 08:49 PM
Weiboy718's Avatar
Weiboy718
pls take a look at his vendor status lol!
former vendor means he's no longer a vendor here hahahahaha.
try AmplifiedMotorSports.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
sLADe781
32
Nov 28, 2015 03:23 AM
ladydriveng37
Oct 11, 2015 05:23 AM
WillCo1
Sep 1, 2015 11:31 PM
MeatySock
Aug 14, 2015 08:25 AM
