Sponsor Infiniti Akebono 14" Brake Kits for 07+ G35/G37 Sedan, 08+ G37 Coupe
Old Mar 6, 2011 | 02:41 AM
  #46
G35_FTMFW's Avatar
G35_FTMFW
SPECIAL DISCOUNT price for drilled and slotted rotors for Sport brakes to 33615 (stoptech)
Old Apr 26, 2011 | 01:53 PM
  #47
buffpatel's Avatar
buffpatel
Please PM me price to 43081 if this is possible: Akebono Infiniti G35 / G37 F & R 14 Inch Big Brake Kit w/ Stoptech Rotors (slotted). I would like to have Hawk ceramic brake pads in the kit instead of the OEM pads if possible. Please send the price with and without SS line (as I'm debating on that one). I have an 09 G37x sedan. Thanks.
Old Apr 26, 2011 | 02:18 PM
  #48
Damn Dirty Ape's Avatar
Damn Dirty Ape
Originally Posted by Coz@Czp
The rear dust shield is the only one that takes some time, the front ones comes right off when you remove the front bearing. Bleeding is annoying as usual, and that's it
So the front shield has to be removed? and the rear trimmed. Do I have it right now?
Old Apr 26, 2011 | 02:53 PM
  #49
Coz@Czp's Avatar
Coz@Czp
Yes, you have it right
Coz
Old Apr 26, 2011 | 02:56 PM
  #50
Coz@Czp's Avatar
Coz@Czp
PM sent, thx
Old Apr 26, 2011 | 04:21 PM
  #51
ESSRTEE8's Avatar
ESSRTEE8
Can you tell me upside/downside or stock rotors vs. slotted vs. drilled vs. slotted and drilled for the BBK?
Old Apr 26, 2011 | 05:11 PM
  #52
Coz@Czp's Avatar
Coz@Czp
OEM = Boring
Drilled/Slotted, Slotted, or Drilled = Fun But if track the car, only get slotted, the drilled rotors will crack overtime. If you daily drive the car w/ rare track time, any drilled setup will be just fine.
Old Apr 26, 2011 | 05:35 PM
  #53
ESSRTEE8's Avatar
ESSRTEE8
ok,
so drilled/slotted then?
Centric pads too.
PM price to 10962
Old Apr 26, 2011 | 05:50 PM
  #54
Coz@Czp's Avatar
Coz@Czp
ok,
Centric pads too.
PM price to 10962
PM Sent, thanx.
Old Apr 26, 2011 | 08:42 PM
  #55
Jubbliepuff's Avatar
Jubbliepuff
price of drilled/slotted rotors for front and rear to 08901 please! Thanks
Old May 27, 2011 | 04:25 PM
  #56
simonsez's Avatar
simonsez
pls quote me on Akebonos F & R with slotted rotors all around ship to 11413
does Akebono calipers come in silver only?
Old May 27, 2011 | 11:31 PM
  #57
RaizinCayne's Avatar
RaizinCayne
2pc Rotor Sneak Peak:
I just got these in Friday, they look beautiful. These are DBA 5000 Series Discs, and our own CZP 6061-T6 Aluminum Hat. These hats are based off the same tolerances and specifications that DBA uses for all their 5000 Series 2pc Rotors. We are going to test these for 30 days, and then put them into production with a release date to follow.
With our past experience, we tried to cut down the weight as much as possible, but we kept having cracking and warping issues. So we decided to go with more durable disc, and a thicker hat. The DBA Kangaroo Paw Design provides this stronger disc, but with more material, there is more weight. The combination of the Thicker Hat and DBA Kangroo Paw Design, each front rotor will weigh 22lbs, which is still 8lbs lighter then stock. We were thinking of going with a thinner 7075-T6 Aluminum, but then the price would almost double. But we are very happy with this setup now, mainly because of the durability and quality.
Hats are bare aluminum right now, but they will be anodized black or maybe a signature color if we get enough requests. There are no plans for rear 2pc rotors at the moment. Pricing looks around $650-700 per set, or $550-600 when sold w/ a Akebono Kit. More News to come
What is the status with these? I would hope that by now you would also have a set for the rears? Unless this never worked out? Interested....
Old May 28, 2011 | 01:27 PM
  #58
Djfarhan's Avatar
Djfarhan
the infiniti BBKs dont fit the X sedans right?
Old May 30, 2011 | 07:28 PM
  #59
Coz@Czp's Avatar
Coz@Czp
Only Fronts right now, no plans for the rears.
Old May 30, 2011 | 07:30 PM
  #60
Coz@Czp's Avatar
Coz@Czp
The Akebono Kit will fit on any model. Only the older 03-06 Sedan and 03-07 Coupe G35s require Brackets.
