Infiniti Akebono 14" Brake Kits for 07+ G35/G37 Sedan, 08+ G37 Coupe
These kits are now ready for 08+ G37 Coupes, 07+ G35/G37 Sedans, and 09+ 370Zs. As we all know, Sport models already have these large brakes on them. It's also nice to know that paying to upgrade to a 14" Big Brake Kit is not gonna cost a Arm and Leg. These Kits are all direct bolt on, no additional hardware needed. The only modification that is required is shaving the dust shields. Stock Brake Lines, or upgraded SS lines will work on these systems. More options for Rotors and Pads as they become available.
In the Media, Akebono Kit in Modified Magazine: http://www.conceptzperformance.com/i...edmagazine.jpg Need to check and make sure they will fit your rims, no problem, you can use our Front wheel fitment Template: Front Wheel Fitment Template Rear Wheel Fitment Template Akebono Infiniti G35 / G37 F & R 14 Inch Big Brake Kit w/ Stoptech Rotors, 07+ Sed, 08+ Cpe: $1620 http://www.czp.us/cart/images/3240l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ Akebono Infiniti G35 / G37 Front 4-Piston 14 Inch Big Brake Kit w/ Stoptech Rotors, 07+ Sed, 08+ Cpe: $1155 http://www.czp.us/cart/images/3239l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ Akebono Infiniti G35/G37 Front 4-Piston 14 Inch Big Brake Kit: $995 http://www.czp.us/cart/images/2921l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ Akebono Infiniti G35/G37 Rear 2-Piston 13.8 Inch Big Brake Kit: $695 http://www.czp.us/cart/images/2922l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ Akebono Infiniti G35 Front & Rear 14 Inch Big Brake Kit: $1425 http://www.czp.us/cart/images/2920l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ Stoptech Rotors: Slotted http://www.czp.us/cart/images/2936l.jpg Front Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Front Non-Sport: http://www.conceptzperformance.com/images/cart2.gif Rear Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Rear Non-Sport: http://www.conceptzperformance.com/images/cart2.gif _________________________ Drilled: http://www.czp.us/cart/images/3049l.jpg Front Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Front Non-Sport: http://www.conceptzperformance.com/images/cart2.gif Rear Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Rear Non-Sport: http://www.conceptzperformance.com/images/cart2.gif _________________________ Drilled/Slotted Drilled: http://www.czp.us/cart/images/3060l.jpg Front Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Front Non-Sport: http://www.conceptzperformance.com/images/cart2.gif Rear Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Rear Non-Sport: http://www.conceptzperformance.com/images/cart2.gif _________________________ Hawk Pads: HPS http://www.czp.us/cart/images/2992l.jpg Front Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Rear Sport Akebono: http://www.conceptzperformance.com/images/cart2.gif Front Non-Sport : http://www.conceptzperformance.com/images/cart2.gif Rear Non-Sport: http://www.conceptzperformance.com/images/cart2.gif __________ Performance Ceramic http://www.czp.us/cart/images/2984l.jpg Front Sport: http://www.conceptzperformance.com/images/cart2.gif Rear Sport : http://www.conceptzperformance.com/images/cart2.gif __________ HP Plus http://www.czp.us/cart/images/2988l.jpg Front Sport: http://www.conceptzperformance.com/images/cart2.gif Rear Sport : http://www.conceptzperformance.com/images/cart2.gif _________________________ Motul Racing Brake Fluid 3-Pack http://www.czp.us/cart/images/3058l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ CZP G35 / G37 Teflon Coated Stainless Steel Brake Lines http://www.czp.us/cart/images/2776l.jpg http://www.conceptzperformance.com/images/cart2.gif _________________________ http://image.automobilemag.com/f/mul...oduction+3.jpg |
Price for the following shipped to NY 11413 as well as the total weight of the package.
Akebono Infiniti G35 / G37 F & R 14 Inch Big Brake Kit w/ Stoptech Rotors, 07+ Sed, 08+ Cpe: $1620 thanks! EDIT: Can i choose which Stoptech rotor comes with the package? |
I have an 2009 G37 sedan with premium wheels 18 inch (non sport), will this brake upgrade clear my rims? and when it says bolt on everything should fit as is without any changes?
price for Akebono Infiniti G35 / G37 F & R 14 Inch Big Brake Kit w/ Stoptech Rotors, 07+ Sed, 08+ Cpe: $1620 shipped to california 91790
btw, what is the main difference bet the slotted and grilled rotors?
What is the dust cap?
Jqueen, you should be all over this.
Originally Posted by Blackjack
(Post 2741483)
Has anyone done this for a 2009 G37X COUPE?
Best, Chris |
ahh the infamous concept z guys. Now go make my car a badasss poly urethane bumper like u guys did for the 35!! G0o0o0o0o0o!!! :) bump
Originally Posted by cconklin1
(Post 2743220)
Best, Chris |
2pc Rotor Sneak Peak:
I just got these in Friday, they look beautiful. These are DBA 5000 Series Discs, and our own CZP 6061-T6 Aluminum Hat. These hats are based off the same tolerances and specifications that DBA uses for all their 5000 Series 2pc Rotors. We are going to test these for 30 days, and then put them into production with a release date to follow. With our past experience, we tried to cut down the weight as much as possible, but we kept having cracking and warping issues. So we decided to go with more durable disc, and a thicker hat. The DBA Kangaroo Paw Design provides this stronger disc, but with more material, there is more weight. The combination of the Thicker Hat and DBA Kangroo Paw Design, each front rotor will weigh 22lbs, which is still 8lbs lighter then stock. We were thinking of going with a thinner 7075-T6 Aluminum, but then the price would almost double. But we are very happy with this setup now, mainly because of the durability and quality. Hats are bare aluminum right now, but they will be anodized black or maybe a signature color if we get enough requests. There are no plans for rear 2pc rotors at the moment. Pricing looks around $650-700 per set, or $550-600 when sold w/ a Akebono Kit. More News to come :) http://www.conceptzperformance.com/i.../2pcrotor1.jpg http://www.conceptzperformance.com/i...rotorrear1.jpg http://www.conceptzperformance.com/i...torcorner1.jpg http://www.conceptzperformance.com/i...crotortop1.jpg |
^^^ These are HOTT!!!
would this fit nonsport?
^^ very nice rotors!
will you have drilled and slotted ones as well? |
