Removing calipers when replacing brakes and rotors
Old Feb 16, 2024 | 12:27 AM
Scottfreidel's Avatar
Scottfreidel
Hey guys,
I am in the process of replacing all 4 brake pads and rotors on my 09 g37s. All the videos I have watched, the person doesn't disconnect the caliper. I would like to clean up my calipers. I noticed some wear on the piston seals so I want to reseal the calipers as well. This would all be easier if the calipers were disconnected from the brake lines. I already plan to use the Phoenix system tool to bleed the brake lines. So my question .. is there any harm or risk in disconnecting the calipers if I am bleeding the brake lines anyway?
Thanks 😀
Old Feb 16, 2024 | 09:40 AM
ILM-NC G37S's Avatar
ILM-NC G37S
None at all. Just cap off each brake line as you remove the caliper to prevent spillage of brake fluid and also to prevent moisture from creeping into the line.
Gnomercy1337
13
Jan 16, 2019 09:59 AM
G37Camel
Jun 17, 2016 02:59 PM
HS125
Feb 11, 2016 11:27 AM
Cobraredz
Dec 29, 2013 12:01 PM
