Help Smacked a curb and bent the wheel
Old Apr 22, 2023 | 03:56 PM
Jojo5owe9's Avatar
Jojo5owe9
Hi guys I did a dumb thing yesterday and tried to drift my g37 and ended up smacking a curb pretty hard I tried to take the wheel off but one of the bolts is froze on so I came here to see if any of y’all had advice or opinions on what should be changed(I will ad pics)
I can tell the bottom link if defn bent and will need to be replaced but I can’t tell about the rest until I can get the tire off maybe but I think it might be the bottom link the top link looks a little bent but the subframe, tie rod all look good upon inspection want to fix it myself and not bring to a shop any help
Ik the wheel hub might be bent and axle but I’m hoping not
Old Apr 25, 2023 | 01:11 AM
Birdie's Avatar
Birdie
Where you able to get your wheel off? I would put the lug nuts back on tightly and then tighten the lug that is froze. Yes try and make it a bit tighter to see if it breaks then back it off. And far as everything else. you will probably have to do it piece at a time till your alignment is correct.
TonyG1215
Jan 24, 2022 12:54 PM
JohnnysG
Apr 10, 2011 10:08 PM
joey'g37
Northern California
14
Sep 14, 2010 04:16 PM
Mike
Apr 2, 2010 05:54 PM
