Wheel Questions for the Vert
Old Feb 3, 2022 | 11:05 PM
R3born's Avatar
R3born
Hey all! Finally got my first G37 after much debating. Decided to go with a convertible G37S.
I’m looking at wheels and found a killer deal for 19x9.5 +25 and 19x10.5 +25 and want to know if they’d fit and/or what I would need to do to make them work.
Old Feb 3, 2022 | 11:23 PM
Said Amir's Avatar
Said Amir
https://www.myg37.com/forums/wheels-...-question.html
^based on this it will stick out unless you lower it and put some camber with it
https://www.fitmentindustries.com/wh...tein-coilovers
^This set up is a Front: 19x9.5 +25 Rear: 19x10.5 +32 just to give some perspective as to how it will look when you lower it
https://www.customwheeloffset.com/wh...tein-coilovers
^This set up is a Front: 19x9.5 +22 Rear: 19x10.5 +22
If you plan to drop it, it should work. If you are going to keep stock height then it will just stick out and look weird.
Old Feb 3, 2022 | 11:47 PM
R3born's Avatar
R3born
Thank you. I keep seeing that some people say it won’t clear the front caliper but others fitting it without an issue.
I am planning on lowering as well.
Old Feb 4, 2022 | 01:31 AM
Said Amir's Avatar
Said Amir
Brakes as in big brakes? I have big brakes and I am running a 19x8.5 +35 square set up and no issues. I think you should be able to clear it with +25
Old Feb 4, 2022 | 02:44 AM
Birdie's Avatar
Birdie
The offset is half the battle with clearing the front brakes. The other is the design of the wheel itself.
cereal2k
G37 Convertible
22
May 28, 2018 02:10 PM
cereal2k
G37 Convertible
45
Jan 27, 2015 01:06 PM
cereal2k
G37 Convertible
Apr 17, 2010 08:38 PM
AZ_Matt
Buying & Leasing
16
Nov 17, 2009 01:59 AM
