Problem with brakes
Problem with brakes
I am experiencing a problem with the brakes recently where when braking even slightly, the seat belts would lock up and squeeze as if I'm braking hard. I have took the car to get inspected by a technician and he does not know what seems to be causing this. He has told me that the brake pedal has been lowered but doesn't know why or what has caused it. The brake pads are fairly new and has still has a lot of life left in them. He has also flushed the brake system and there is no leak nor air in the system. Brake fluid is at an adequate level (mid way). Does anybody know what may be the causing this issue?
I have done a big brake kit (Akebonos) and the rotors are good/fairly new.
Nissan Brake Recall
While I have not heard of this happening with any G's, it might be something to look into...
