Coupe Rear Subframe Crossmember on Sedan?
I broke the rear subframe support brace/crossmember. I found some new ones on eBay but I can only find ones off coupes. Will this work on my sedan? I got a 2012 g37X
https://www.ebay.com/itm/114482763317
example of the ones I’ve found so far. I can’t find any listed as from a sedan
I don't have the answer, but would suggest going to your local dealer and asking the parts department. At least they can look up the subframe and see if there's a different part # for the sedan vs. the coupe. How did you break the rear subframe assembly? That's an extremely hefty and sturdy aluminum section.
StopTheExcuses
Oct 23, 2009 01:54 PM
