Is my G lowered?
Old Oct 15, 2019 | 07:36 PM
tbssimp's Avatar
tbssimp
Is my G lowered?
So I am having major tire wear issues. Only got 5k out of my back tires, I know I should have been checking the wear just been busy. Fronts are doing great though. I have not been able to get an alignment either so I went to a shop today and they said they can't do it because it's lowered and they can't get it on the lift.
My first question is, is it really lower? I bought the car like it is.
Second it's my understanding unless it completely slammed which it isn't a shop with an in-ground lift can still do the alignment. Is that true?
I'm not mechanically inclined so any help is greatly appreciated.
Old Oct 15, 2019 | 09:28 PM
Infin88's Avatar
Infin88
Doesnt look lowered, but those arent oem rims/tires. What are the specs
Old Oct 15, 2019 | 09:39 PM
tbssimp's Avatar
tbssimp
Correct. They are 245,45,18 tires on 2014 Maserati Ghibli Alfieri wheels.
Old Oct 15, 2019 | 09:58 PM
Infin88's Avatar
Infin88
An alignment might bring everything back to spec if that is the issue
edit: forgot that you mentioned they couldnt get it on lift. Go to a different mechanic. Im lowered on springs and it’s a mild drop...my mechanic cant do oul changes anymore so i gotta go to a car wash/oil change spot because they have the underground bays...annoying
i mean...lowered cars get alignments and work done all the time...i just think it’s not worth the trouble for some of these guys
another note: did you get your Sidemarkers ( orange strips) modified. It looks gray in one of the pics
Old Oct 16, 2019 | 12:43 PM
NealP's Avatar
NealP
As others have said, that does not look lowered. They probably just don't have a lift low enough or don't want to go near your car, which if they think that's lowered then they aren't familiar with G's and you should probably look elsewhere anyway. I remember when I first got my G I called a shop and they said they won't touch it. They just don't have experience with G's it and it's not worth it for them. Business must be good. Also, when you say major tire wear is it even or uneven wear? Depending on how bad it is you might be able to rotate them and get more life but definitely get an alignment. Especially if it's uneven wear.
Old Oct 16, 2019 | 03:02 PM
Surfnazi's Avatar
Surfnazi
My g bought new was off spec on alignment with 90 miles on it, they realigned it to middle.of each spec
Old Oct 18, 2019 | 01:57 PM
tbssimp's Avatar
tbssimp
Thank you. No the sidemarkers are stock its just a the filter on the picture.
Old Oct 18, 2019 | 01:58 PM
tbssimp's Avatar
tbssimp
Thanks everyone. Sounds like I just need to find the right shop.
Old Oct 21, 2019 | 12:34 PM
teahead's Avatar
teahead
Wow, my car is pretty slammed and the Nissan Dealer who did the oil change, had no issues.
Your car definitely doesn't look lowered.
THIS is lowered.
Doggy
Southern California
Aug 8, 2011 01:00 AM
911turbo
Feb 24, 2011 10:46 PM
G37Sam
Mar 9, 2009 12:22 PM
