AKEBONO discoloration after brake bedding procedure!!!
Old Oct 5, 2019 | 01:31 AM
x818ray's Avatar
x818ray
After doing the brake bedding procedure to get rid of minor brake judder, and possible brake pad deposits on the rotor, my calipers turned a different color from all the Heat. The smell was pretty bad too. I did do several more than the recommended 10 stop and go passes, never experiencing brake fade, but I never expected this to happen. After 8 plus years of regularly going through threads on this forum I've never heard or seen it happen before. It's not the first time I've done the procedure, and a quick search didn't provide any answers. I'm not exactly happy about it..
Old Oct 5, 2019 | 02:38 AM
Said Amir's Avatar
Said Amir
That’s pretty weird. Unless it was repainted and the clear coat yellowed out from too much heat
Old Oct 5, 2019 | 03:08 AM
ngolbuff's Avatar
ngolbuff
@4DRZ didn't this happen to you too? (but at the track?)
Old Oct 5, 2019 | 03:24 AM
x818ray's Avatar
x818ray
That would be my first thought too... I bought the car new though. To add to this, the brakes got smoking hot.
Old Oct 5, 2019 | 07:14 AM
Greenhorn's Avatar
Greenhorn
Honestly it looks like the heat might've messed with the coating causing the discoloration. I've never seen this in person but have heard of it happening.
Old Oct 5, 2019 | 08:12 AM
Originally Posted by x818ray
After doing the brake bedding procedure to get rid of minor brake judder...
Did it work? Is the judder gone?
I was under the impression that there is no bedding procedure for Akebono pads, just 400-500 miles of light braking.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=85
Old Oct 5, 2019 | 02:32 PM
bPChaos's Avatar
bPChaos
Most street brake pads don't need a bed in procedure, just light driving as Rochester said. As for the calipers, it's just heat discoloration. Mine got like that after the track.
Old Oct 7, 2019 | 06:14 AM
Surfnazi's Avatar
Surfnazi
Did you get brake fluid on them, brake fluid will eat paint
AMai1215
Jan 13, 2015 12:54 AM
JEBperformance
Brakes/Suspension
22
Nov 30, 2011 02:04 PM
Kromber2
Apr 26, 2011 03:25 PM
colburs
Mar 2, 2010 06:25 AM
