Help Cv boot grease
Old Feb 26, 2019 | 04:18 PM
BluesG's Avatar
BluesG
Cv boot grease
Well after searching for a good bit. I haven't seen any info on what kind of cv grease most use when replacing boots.
Plenty of topics about oil, diff fluid, atf etc.
I'm guessing most don't repair torn boots?
Old Feb 26, 2019 | 04:47 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I don't recall reading any posts about torn boots. I imagine grease typically used for cv repairs would be applicable. The FSM probably tells you exactly what to use. Check there?
Old Feb 26, 2019 | 05:17 PM
Baadnewsburr's Avatar
Baadnewsburr
2nd hand CV axles for these cars are so plentiful and cheap its mostly not worth it.... especially given the extra time it takes to rebuild compared to a straight swap...
Old Feb 26, 2019 | 06:21 PM
stealthee's Avatar
stealthee
Most boot kits comes with grease anyway, but agree with Hashim its just simpler to replace the whole axle.
Old Feb 26, 2019 | 06:42 PM
ILM-NC G37S's Avatar
ILM-NC G37S
The FSM just states to use "genuine Nissan grease or equivalent." From my experience, any quality wheel bearing grease will suffice. Just do not overpack the joint else you will have problems with the boot sealing/blowing out/tearing. Been there, done that. Grease goes in the joint after the inner race, cage and steel ***** are assembled into the outer race, NOT in the boot. Been there, done that...
I have rebuilt quite a few CV axles over the days (not for this car) and take my advice for what it is worth: just swap the whole axle assembly. The aggravation you will save is priceless... unless you just want the experience.
Old Feb 26, 2019 | 11:18 PM
BluesG's Avatar
BluesG
Well I did replace the half shaft on the drivers front. That wasn't a fun experience lol. Supposedly it had 43k on it and in less then 2 days it torn the boot.
I thought I would just replace the boot, clean them up and repack them with grease since I caught it in time.
How much is to much grease in the joints?
Old Feb 27, 2019 | 09:28 AM
ILM-NC G37S
Those rubber boots, for some cars, are more aggravation than they are worth. Audi and Cadillac, back in the day, were always problematic. Anyhow...
2010 G37 Sedan FSM Index
Sections FAX (FRONT AXLE) and RAX (REAR AXLE), both provide good, detailed instructions on the CV joints. The procedures are the same whether coupe or sedan and model year.
There is no set specific amount of grease to use (ie. "X" many ounces). The aggravating part will be the band clamp...always was for me.
Good luck!
Old Feb 27, 2019 | 10:40 PM
BluesG's Avatar
BluesG
I think I will be needing the luck. I'll just take my time and if I get to aggravated I'll go get some new ones lol. Thanks for all the info.
I did find this in the FSM, Just in case someone else searches for it
----------------------------------------Wheel side--------------------------------Front final drive side
Grease quantity -------Left side 77 – 97 g (2.72 – 3.42 oz) -----------95 – 105 g (3.36 – 3.70 oz)
-----------------------------Right side 77 – 97 g (2.72 – 3.42 oz)----------113 – 123 g (3.99 – 4.33 oz)
san~man
Dec 17, 2013 09:26 PM
NYG37S
Oct 17, 2012 02:53 AM
YetiTL
Jun 6, 2012 08:16 PM
G37Sam
Feb 13, 2012 01:54 PM
XMMAN
Car Care & Detailing
Mar 15, 2009 01:07 PM
