It worked perfectly. It's all legit. Just make sure to get all the parts you need. Specially the banjo bolt for the sports model. You also need something to cut the rotor dust cover. I used a heavy duty sheet metal cutter in the front and just hammered the rears so it's not touching the rotors.
I painted mine burnt copper.
You're a real champ for this one. Definitely getting these for my 09' G37x asap.
Either eBay or Amazon, I forgot. Take your time with prep work, specially with sanding the callipers. The rougher the better. Lay multiple coats of primer so the paint has something to grab onto. Be generous. Just an advice and goodluck with your project.
