Help Front sway bar bracket
Old May 9, 2018 | 06:06 PM
KenKannon's Avatar
KenKannon
Hello! I tried doing some googling and on here but no dice...so I went over a bad pothole a while back that bent (and it may of broke by now I've been driving on it the last couple weeks I think I have to lift it up) the `U` (for lack of a better term) I guess bracket that the sway bar and end links attach to the chassis and was wondering if anyone here can point me in the right direction in getting a replacement or repairing it...it's so floppy now when taking corners!
Old May 9, 2018 | 09:55 PM
hurleyguys's Avatar
hurleyguys
here you go i think this is what you are looking for. but be sure to get under your car adn check it is the correct part that you need
but the bracket is called a clamp stabalizer and i think it has a right and left side. the right side is part nummber 54614AL500
that part number is also for a 2012 g37 sport coupe. not sure what you got but it will point you in the right direction.
https://parts.infinitiusa.com/nissan...partcode=54614
here is the site i found it on.
Old May 10, 2018 | 03:42 AM
KenKannon's Avatar
KenKannon
Thanks bud appreciate it...so CHEAP! yay was dreading it being way more...I can imagine what the equivalent would cost on one of the big german makes I'll lift it up and double check...probably gonna need a new endlink too...such is life.
Old May 10, 2018 | 10:27 AM
Baadnewsburr's Avatar
Baadnewsburr
are you sure it was the clamp/bracket? Its more likely a sway bar end link that snapped given the scenario you mentioned
emyrl
Apr 8, 2018 12:02 PM
ReplicaR
Jun 21, 2017 02:51 PM
mjnoles1
Dec 18, 2015 10:19 PM
Kevalteam
May 20, 2014 11:29 AM
Genseven
Aug 11, 2010 05:30 PM
