2013 AWD sedan how high will coilovers adjust
Old Oct 13, 2017 | 12:36 PM
Surge Shamray's Avatar
Surge Shamray
looking for mostly better handling via dampening adjustments however not in the market for super low maybe just a bit lower than stock
Old Oct 15, 2017 | 05:50 PM
Might send a PM to some of the AWD guys that have coilovers and see how much adjusting range they have. A lot of the coilover data on the company websites isn't very accurate from what I've seen.
It may also be possible to order longer springs if you want a milder drop, would have to contact the companies for that.
Old Oct 15, 2017 | 05:59 PM
Flannigan's Avatar
Flannigan
I just installed Fortune Auto 500 coils on my 2013 X Sedan. The rear coils are set 85% as high as they go and it measures 26.5 inches from the ground to center of fender. It is very low and has nearly no room to be raised. This is with the springs that come with the kit not the swift upgrades.
Old Oct 16, 2017 | 01:21 PM
bPChaos's Avatar
bPChaos
I think longer springs may not necessarily solve the issue though, as from what I've seen, most height adjustment comes from a threaded shock body and collar, which limits adjustment. He'd have to find a longer shock, as there's only so much travel the damper itself can move.
Old Oct 16, 2017 | 02:15 PM
Should have been more specific, was referring to the OEM setup where the spring is separate from the shock. Once the height collar is fully extended the spring is the only way to get further height.
And yeah, would be something you'd have to consult w/ the company about, as the shock length may be outside it's recommended operating range (or even maxed out) w/ a different spring height.
Old Oct 19, 2017 | 09:34 PM
Surge Shamray
do you recommend them?
Old Oct 19, 2017 | 09:37 PM
Surge Shamray
thinking about offering AWD sedan guys 20 bucks via PayPal to raise their coils all the way and send me pics and measurements lol
anyone interested?
