Little Wobbly
Old Apr 13, 2016 | 10:00 PM
JeffG37x's Avatar
JeffG37x
Little Wobbly
Recently put a set of staggered 20's on. Love the look but at higher speeds 70+ the car gets a little shakier than I am used to. Had wheel balance double checked and it was all good so I am guessing this is normal but wanted to see if others have experienced this.
Old Apr 13, 2016 | 10:07 PM
Ricio1991's Avatar
Ricio1991
I didn't have that problem when I had staggered 20's on my coupe, check your aligment or maybe the tires. Doesn't seem normal
Old Apr 13, 2016 | 10:10 PM
monytx's Avatar
monytx
Did you use hub centric rings?
Old Apr 13, 2016 | 10:17 PM
juan goose's Avatar
juan goose
This is normally overlooked and cures the wobble
Old Apr 13, 2016 | 10:21 PM
G37xhibeet's Avatar
G37xhibeet
What they said. Happened to me when I put my 20s on as well
Old Apr 13, 2016 | 11:10 PM
JeffG37x's Avatar
JeffG37x
I'll have to get this checked out. I had them installed for the first time at a tire shop where I bought the tires. My guess is normally they don't add rings right so they missed it?
Old Apr 13, 2016 | 11:36 PM
Are you also running wider tires? Some wider tires are more prone to tramlining, and can get pretty bad on grooved roads.
Old Apr 13, 2016 | 11:56 PM
JeffG37x's Avatar
JeffG37x
275 in the back and 245 up front. Literally it only happens 70+ mph. So I either need centering rings or it is what it is I am guessing .
Old Apr 14, 2016 | 08:52 AM
VenomGT9's Avatar
VenomGT9
What wheels did you buy?
Old Apr 14, 2016 | 09:08 AM
JeffG37x's Avatar
JeffG37x
I have stance sc5 wheels 20x9 +32 and 20x10.5 +27. What size centering rings do I need I am assuming they need to match.
Old Apr 14, 2016 | 09:34 AM
G37xhibeet's Avatar
G37xhibeet
Your hubs are 66.1mm. You need to figure out what the hub size of the wheels are and get hub rings with an inner diameter of 66.1 and an outer diameter to match your wheels
Old Apr 14, 2016 | 10:47 AM
VenomGT9's Avatar
VenomGT9
You probably bought 73.1 hub wheels
Old Apr 14, 2016 | 11:11 AM
juan goose's Avatar
juan goose
https://www.myg37.com/forums/g37-sed...-to-shake.html
Old Apr 14, 2016 | 11:43 AM
JeffG37x's Avatar
JeffG37x
Had centering rings installed this morning. Totally fixed the issue. Thanks guys!!!
Old Apr 14, 2016 | 12:27 PM
VenomGT9's Avatar
VenomGT9
Well done, enjoy
Moe_G37x
MODDING 411
May 17, 2016 10:10 AM
zib331
Apr 14, 2016 11:36 AM
7Head
Apr 10, 2016 08:22 PM
Romanog37x
Apr 8, 2016 09:30 AM
