Help Are my new wheels causing acceleration lag?
Old Apr 5, 2016 | 12:37 PM
  #46
JSolo's Avatar
JSolo
Just say no!!!!!
Don't rely on anyone but yourself. Most vendors are middlemen and have little technical idea of what they're selling. As mentioned, perform your research so you know exactly what you're getting and what should fit.
Wheels are a funny business to be in. There so many layers to fitment. Fitment aside, there's the issue of safe handling. For example, wheels that stick out too much put uneven load on the hub. Resulting in premature hub bear wear. Some don't care about this as they're in it strictly for the looks.
According to michelin, the pilot super sport in 245/40/19 will fit a rim of 8-9.5". Their printed tire specs (diameter, revs per mile, etc..) are based on a rim width of 8.5". I would of looked up your specific tire, but you didn't specify an exact toyo proxy model.
Old Apr 5, 2016 | 12:38 PM
  #47
Gatson1983's Avatar
Gatson1983
Originally Posted by Ryne
I'm glad the vendor is working with you. Right or wrong, he may have left out the discussion of offsets to simplify the transaction since you made it clear you were a novice at wheel/tire fitment. Offsets can be extremely confusing and complicated, and are hard to explain over a short phone call. Offsets are also only part of a complex equation that results in the final fitment. Alignment specs play a huge factor in final fit. A difference in a degree or two of camber makes the same size wheel look either past the fender, in line, or slightly tucked.
Did you end up with Forgestar wheels?
I think he may have left that part out to simplify it as well. That was my best assumption, at least. I ended up with the TSW Bathurst actually. The more i looked into the actual weight, the more I felt I wasn't going to get anywhere near what was advertised.
Old Apr 5, 2016 | 01:16 PM
  #48
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
hey is my email with jason when i was looking for wheels
Mar 8, 2016 at 9:16 AM, CHUCKIE D
Jason can i get a quote for 18x8.5 offset +35 5x114.3 Enkei RPF1 Matte Black with TPMS
with tires toyo Proxes 4 on 245/45/18
To: CHUCKIE D
Sent: Tuesday, March 8, 2016 4:08 PM
Subject: Re: MYG37
$1999 shipped for 18x8.5 +30 RPF1 with 245/45/18 Toyo Proxies 4+ and TPMS with black valve stems
You can give me a call at 562-219-2525 to discuss or place your order, I can also send you a Paypal request to get your order started right away.
Let me know what is most convenient for you and we'll get it going!
Regards,
Jason
On Tue, Mar 8, 2016 at 4:22 PM, CHUCKIE D wrote:
+30 wont work for me I need to stay +35 +38 or +45
On Mar 9, 2016, at 11:07 AM, Jason Tung wrote:
I have 18x8.5 +40 5x114.3 in +40 available, silver and gold in stock!
Same cost $1999/set shipped
Let me know if these will work
No thanks I only wanted black..
Chuckie
Old Apr 5, 2016 | 01:22 PM
  #49
chuckie311's Avatar
chuckie311
if you notice the email he sent back was not what i was asking for..he could have just said i don't have Matte black in 18x8.5 +35 in stock.
instead he quotes me a 18x8.5 +30 in silver
Old Apr 5, 2016 | 01:33 PM
  #50
JSolo's Avatar
JSolo
Just say no!!!!!
Assuming both clear the calipers, realistically speaking, how much difference is there in a +30 vs +35mm offset? Numerically it's 5mm, but does that translate into a significant visual difference?
Old Apr 5, 2016 | 06:21 PM
  #51
evil-G-nius's Avatar
evil-G-nius
Originally Posted by chuckie311
What did you think they weighed?
Honestly, no effin clue! LoL
222lbs just seems like a lot to me for some reason
Old Apr 6, 2016 | 12:58 PM
  #52
Gatson1983's Avatar
Gatson1983
So this is the email I was given this morning:
It really depends on the condition of the wheel that was mounted.
If the wheel is perfect with no scratches and TSW cant tell the tire was ever mounted then we'll get them swapped out for you no problem
Only other option available is 19x8 +35 all around, does that work for you? This fits 18mm further in than the 9
If it is scratched up from the mounting/unmounting TSW wont take it back and we wont be able to return the wheels. On the TSW boxes there is a sticker that specifically states to test fit the wheel before mounting a tire or they wont take the wheel back.
In that case then I can have the wheels shaved 3mm for you to make them a 19x9 +33 and that should fit better
This is a G37 x sedan running 19x9 +30 wheels with 245/40/19 tires and it fits perfect flush
https://www.myg37.com/forums/g37-sed...ml#post3797069
I don't believe they have a mark on them even after lugging them around anywhere. Not quite sure on how I feel about them shaved down.....but, one bridge at a time.
Old Apr 7, 2016 | 03:05 PM
  #53
chuckie311's Avatar
chuckie311
well for one they didn't have the matte black i was looking for.
and if i wanted a +30 offset i would have asked for it..
the point of the story is i asked for a specific wheel and offset and he tries to sell me something i didn't want or ask for.
Old Apr 7, 2016 | 03:31 PM
  #54
Ryne's Avatar
Ryne
The Steering Wheel Guy
The marks will be on the outer part of the barrel from mounting the tires (the part of the wheel covered currently by the tires). The marks will almost certainly be there. This is just a fact of life when mounting tires.
Old Apr 7, 2016 | 03:34 PM
  #55
Ryne's Avatar
Ryne
No offense (just rationalizing), but I didn't see anything too bad about his e-mail. He's a sales guy trying to make a sale and went out of his way to let you know your other options. Sometimes people are flexible on wheel color and what's in stock sways them one way or another. I know this happened when I ordered my wheels. It was nice to know my options.
Old Apr 8, 2016 | 12:28 AM
  #56
chuckie311's Avatar
chuckie311
Understandable but if I was Looking for options I would have let him know in my email.
Old Apr 8, 2016 | 01:06 AM
  #57
JSolo's Avatar
JSolo
Just say no!!!!!
I understand that. Especially the color part. You're really interested in a black car but get sold a white one instead.
My question was more so about the significance of 5mm offset (1/4"). That is, just how important is that in the scheme of things so long as the brakes clear.
Old Apr 8, 2016 | 09:04 AM
  #58
Gatson1983's Avatar
Gatson1983
I looked over the two wheels that were actually opened and played around with. There's not a single mark on them; no scratches, smudges, abrasions, gouges, etc. Although the "tire specialists" did mention they could get the tire back off without damage.
I, also, was very surprised at this. But they're flawless.
Old Apr 8, 2016 | 10:05 AM
  #59
Well it could make the difference between a setup that fits fine and one that pokes 5mm, or one that hits the inner fender edge, etc.
Sounds like you were dealing w/ some very conscientious workers, glad to hear they're clean. I've not been so lucky when dealing w/ most tire shops
Old Apr 8, 2016 | 10:13 AM
  #60
Ryne's Avatar
Ryne
I really don't want to be the rain on the parade, but once all 4 tires are completely off, you will see what I'm talking about. Until then, I'll be hoping for the best.
