285/30/19
Old Feb 22, 2016 | 03:30 PM
TeeItHi's Avatar
TeeItHi
my current rear tires set up is 275/35/19 on 19x10 +40 rims. just wondering if going 285/30/19 would be ok? i'm sure its ok but would like to just double check and also will i need camber kit? thanks
Old Feb 22, 2016 | 05:05 PM
If you haven't dropped your suspension you won't need a camber kit, if you have lowered your suspension you probably will, and you must get it aligned if you have lowered it. If you have 7mm to the inside fender edge w/ your 275s you can go to 285s as long as the new tire doesn't run extra wide. The tread block width should be listed on the tire makers' site.
Old Feb 22, 2016 | 05:40 PM
TeeItHi's Avatar
TeeItHi
Oops I forgot to mention that I'm on eibach pro kit.
Old Feb 22, 2016 | 05:47 PM
Stachuu's Avatar
Stachuu
Lets see pictures of the rear side, I want to know how to 275 on the rear looks like on the G.
Old Feb 22, 2016 | 05:51 PM
TeeItHi's Avatar
TeeItHi
Sorry no pics
Sorry no pics, cuz my winter tires are on and the 275 are bald and will be replaced with 285 if it fits without getting camber kit or spacers...
Old Feb 22, 2016 | 09:30 PM
Oops, glossed over the part where you stated 285/30/19s, I wouldn't recommend that thin sidewall, I'd run 285/35/19s, ride won't be nearly as harsh.
Gspinin
Apr 12, 2016 10:42 PM
Mar 17, 2016 04:06 PM
Nhippen
Feb 24, 2016 08:45 AM
staskz
Feb 19, 2016 07:16 PM
