Auto-X
Old Jul 7, 2014 | 10:39 PM
DR.FixThat's Avatar
DR.FixThat
Auto-X
Well i'm a hard person on car's and the stock brakes don't normally hold up. I'm looking to upgrade my 2009 sport brakes with the akebono calipers. The rotors have warped since last winter so i haven;t done any track days this year. I'm shopping for a great set of pads that'll hold up at the track but since be ok for normal driving. Rotors that can take high speed braking at the track and not warp. thought's anyone?
Old Jul 7, 2014 | 11:13 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
How do you have sport brakes that aren't Akebonos?
There a lot of discussions for rotors and pads. The short answer, to save you time, is that track pads are not street pads. If you're that hard on cars, you should have a dedicated set of track pads and one for street use. Stoptech street performance are good street pads, and I recommend carbotech for track pads.
Get a set of two piece rotors if you're serious about auto crossing and road racing. Z1 makes a decent set, as does Disc Brakes Australia. Pair that with stainless lines and motul 5.1 fluid. That's what I use.
Old Jul 8, 2014 | 09:10 AM
chris_s's Avatar
chris_s
if you care at all about class, check to make sure that a bbk upgrade won't move you into modified or something silly like that
Old Jul 12, 2014 | 12:03 AM
DR.FixThat's Avatar
DR.FixThat
Oh I forgot to say, i do have akebono brakes. I just seeing who has what cause i warped my rotors bad. Thanks for the input
Old Jul 12, 2014 | 07:03 AM
Synolimit's Avatar
Synolimit
Most often you don't warp a rotor, you brake pad deposit material on it at different heights. Get them resurfaced, don't set the ebrake when you come to a stop after a run, and try to cool them down before you stop. Try brake duct cooling lines and get a good pad like carbotech and call it a day.
Old Jul 12, 2014 | 02:23 PM
Presto's Avatar
Presto
Get the racing brake 2 pc front rotors and pads. Don't buy their rear 2 pc rotors.
Old Aug 4, 2014 | 01:03 AM
Track Bandit's Avatar
Track Bandit
Why? What's wrong with there rear two piece rotors?
Al
Old Aug 4, 2014 | 09:34 AM
DR.FixThat's Avatar
DR.FixThat
i went with stoptech cyro treated crossed drilled rotors and there pads. So far there great.
Old Aug 4, 2014 | 09:58 AM
GoFightNguyen
Because Racecar
I was at the shop this weekend and found an example of why I personally do not recommend drilled rotors.
txg37x
Jan 11, 2015 06:59 AM
txg37x
Aug 14, 2014 09:13 AM
blkmanual
Dec 17, 2011 01:49 AM
MikeySed
Jul 19, 2010 09:57 PM
REaL
Apr 22, 2010 03:49 PM
