Should Front Wheel Hub Spin Freely?
Old Jan 19, 2014 | 03:14 AM
HoldmyMouse's Avatar
HoldmyMouse
I took my front wheel off and spun my rotor and it was spinning quite nicely, but when I took the rotor off and spun the hub by itself, it wasn't spinning as freely as with my rotor on. Is my hub okay? My car is RWD journey.
Old Jan 19, 2014 | 03:28 AM
G37Sam's Avatar
G37Sam
Were you applying the turning force on the studs in both cases? Or were you turning the rotor itself?
Old Jan 19, 2014 | 11:03 AM
The rotor is a pretty heavy object and the flywheel effect will cause it to turn easier than an unloaded hub if that makes sense.
Old Jan 19, 2014 | 11:19 AM
It will spin more freely with the rotor in it than without it. If you are concerned, check it for play by pulling/pushing on opposite sides. If it rocks in and out, that's a problem. It should be tight.
Old Jan 19, 2014 | 05:07 PM
HoldmyMouse
Yes I was turning by the studs in both cases: with rotor and without rotor. There was no free spin at all when the rotor was off and took a bit of energy to turn it. As far as play goes, I didn't notice any movement. I was wondering because watching video of people replacing brand new hub it seemed like they were able to free spin maybe half turn with minimal effort.
SBG37
May 5, 2022 10:35 AM
james6980
Oct 9, 2015 01:28 PM
gcruzjr78
Aug 18, 2015 10:15 AM
pledes23
Aug 11, 2015 10:54 AM
ddayeg37s
Aug 9, 2015 07:10 PM
