Can I replace my rear sprints on my tanabe coilovers with eibach sprints?
Old Jun 15, 2013 | 12:37 AM
espimax's Avatar
espimax
I am looking to race the rear of my coupe S from the tanabe max high position, it's it possible to replace the rear sprints with other brand that could work with my tanabe coilovers ?
Old Jun 15, 2013 | 09:44 AM
Somebody either posted this while drunk or got their azz kicked by auto correct.
I'd recommend getting Swift springs in the length that will work for what you want to achieve but keep the same spring rates as the springs you are replacing so as to work with the valving of the shocks.
Old Jun 17, 2013 | 11:47 AM
espimax's Avatar
espimax
Thank you, any other brand will work? Like tein H techs etc? How do I look for the spring rates?
Old Jun 17, 2013 | 12:36 PM
Coilover springs and regular lowering springs are different. A set of lowering springs won't fit on your coilovers, so H Techs or something like that won't work.
Off the top of my head I know that Tanabe and Swift make metric coilover springs in various lengths and spring rates. Check their websites to see what they have. The coilover springs in yours are 10 kg/mm front and 9 rear. If you use different springs from the originals they should generally be +/- 2 kg/mm to match the dampers' valving. You can just get a rear pair that's slightly longer.
Old Jun 18, 2013 | 11:05 AM
espimax's Avatar
espimax
I figure since the rear sprints are not part of the strut and they sit by them selves .
Old Jun 19, 2013 | 06:03 PM
slowdown's Avatar
slowdown
I believe Tanabe sells replacement springs if you'd like to keep everything uniform.
Chris Olson
Dec 29, 2025 07:59 PM
SBG37
Mar 12, 2021 03:16 PM
G37xhibeet
Nov 15, 2016 09:29 AM
ladydriveng37
Oct 11, 2015 05:23 AM
MeatySock
Aug 14, 2015 08:25 AM
