Largest Tire without Rub
Old Apr 16, 2013 | 08:36 PM
fennsta_78's Avatar
fennsta_78
I have an 09 X and wondering if I can squeeze 255/45-17's on it. What's the largest size tire anyone has been able to get under there X without replacing the rims?
Old Apr 16, 2013 | 09:06 PM
Yan141's Avatar
Yan141
Ill with 235/50 just to be on safe side.
Old Apr 16, 2013 | 09:19 PM
nukee26's Avatar
nukee26
I don't see an issue with clearance given it's not a whole lot wider and I'm guessing you aren't dropped. Only recommendation is to keep the rolling diameter as close to what you currently have. So if that's a 225/55 like I think sedans are, I'd say go with a 255/50 as it'll get you closer.
Old Apr 16, 2013 | 09:42 PM
fennsta_78's Avatar
fennsta_78
A buddy of mine is closing down his dealership and has a bunch of primacy mxv4 in 255/45-17 and I can buy them for 30 cents on the dollar. And Knowing that in 20K, Ill be replacing the Eagle GT's which are on it now. If they will fit I certainly can't pass this deal up.
Old Apr 16, 2013 | 09:45 PM
nukee26's Avatar
nukee26
Ah... Well as far as them physically fitting I see no issue. Worth waiting around for more opinions, you post this in the Sedan section too? You'll probably get more visibility there.
Old Apr 17, 2013 | 11:15 AM
Just be sure to use this calculator w/ your old and new tire sizes. keep the new diameter within 3% +/- of your old tire's diameter and you'll be OK. obviously as close to 0 is your goal. 255s should fly, might get a bit more center tread wear but other than that should be fine.
Old Apr 17, 2013 | 12:01 PM
Robert_K's Avatar
Robert_K
See my thread in my signature.
Old Apr 17, 2013 | 03:08 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
If a sedan, we show 245/50-17.
Old Apr 17, 2013 | 04:02 PM
fennsta_78's Avatar
fennsta_78
Yes, its a G37 X sedan. Concerned about potholes and such..
RYs06MT
Apr 22, 2016 11:00 AM
drewfinity
Sep 24, 2015 11:01 AM
Simran Mann
Sep 9, 2015 02:08 AM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
