Springs Question! Help
Old Mar 1, 2013 | 01:02 AM
Basicklee's Avatar
Basicklee
Hey guys got a 08 g37s and currently in the market for some aftermarket springs. I am aware of the H&R springs, tein s tech and eibachs however im looking for something that will give me a clean 1.5inch drop front and rear. I like the drop on the H&R's but its too low for everyday driving ( i think its 2inch drop). Tein s techs have a problem with sagging rears after settling and eibachs dont offer enough drop for the money. So i was seeing if theres anything between the H&R's and the eibachs? I Tried searching but couldnt find anything, i apoligize in advance if this is a repost.
Old Mar 1, 2013 | 09:05 AM
Might want to look at the Swift Springs, get great reviews as far as being a comfortable ride for a Daily Driver and the drop is even and won't require camber/toe kits. Here's a couple threads
https://www.myg37.com/forums/g37-sed...rwd-sedan.html
https://www.myg37.com/forums/g37-sed...th-review.html
Old Mar 1, 2013 | 07:02 PM
dtran2714's Avatar
dtran2714
+1 on Swifts
Old Mar 1, 2013 | 07:51 PM
Basicklee's Avatar
Basicklee
you guys know where i can buy a pair of swifts? and is it true you dont need camber/toe kit? i dont want any uneven wear on my tires....
Old Mar 1, 2013 | 08:33 PM
Jomer @ FBParts is a great vendor, just send him a PM w/ your request and he'll get back to you ASAP. He took care of my coilovers w/ the best price and got them in 4 business days. Here's his PM link
https://www.myg37.com/forums/private...newpm&u=339312
Old Mar 1, 2013 | 08:56 PM
dtran2714's Avatar
dtran2714
No camber kit needed for my coupe with Swifts. Alignment was all within OEM specs.
Old Mar 1, 2013 | 08:58 PM
amt120's Avatar
amt120
Swifts are quality springs, you won't regret it. Hope you don't mind the scraping.
Old Mar 1, 2013 | 10:47 PM
Basicklee's Avatar
Basicklee
okay thanks guys. Would you guys say the drop is about 1.5inches?
Old Mar 2, 2013 | 12:49 AM
Can't say since I don't personally own them but from all I've read and the many pics I've seen it looks like it drops just right at 1.5" or a bit less. Certainly not a deep drop.
Old Mar 2, 2013 | 01:01 AM
Basicklee's Avatar
Basicklee
Only concern is if they sag in the rear or not like the tein s techs....
Old Mar 2, 2013 | 03:27 AM
Bota36's Avatar
Bota36
The Swifts for the RWD sedan will lower 1.2 front and .08 in the back.
Old Mar 2, 2013 | 06:27 AM
soundmike's Avatar
soundmike
The man preaches!
This is correct. It's higher than an Eibach drop, but certainly noticeable vs. OEM height.
They also do not sag. I got an alignment a few days after getting it installed. Ride height has remained exactly the same 1k miles later.
Old Mar 2, 2013 | 02:53 PM
Basicklee's Avatar
Basicklee
Would you guys say the drop is the same for the coupe as the sedans?
Old Mar 2, 2013 | 03:57 PM
Basicklee's Avatar
Basicklee
Can anyone relate to ARK GT-F springs? ive seen pictures and do like the drop.
Old Mar 2, 2013 | 04:52 PM
soundmike's Avatar
soundmike
Swift advertises the coupe as 1.3/1 drop. The spring rates are different for it and the sedan.
http://swiftsprings.com/file/ss.pdf
G's
Nov 5, 2023 12:01 PM
Simran Mann
Sep 13, 2015 01:51 AM
elrey85
Aug 30, 2015 04:25 PM
djsunny510
Aug 28, 2015 01:07 PM
