Will 295/30/20s fit inside fender lip?
Old Nov 5, 2012 | 11:14 AM
Going to get AvanteGarde M350s 9" Front 10" rear. The rears have +43 offset and I really want the widest size to match my front Toyos but they only make them in 275 and 295. I think the 285 size would be percfect but they don't make them in that size
I'm lowered on coilovers and I really don't want to go up any higher so the tires will have to fit inside the fender lip. Any help would be much appreciated
Old Nov 5, 2012 | 02:39 PM
Sunny G's Avatar
Sunny G
depending on how low you are if you cut the fender liner in the back a 10" +43 will fit the 295/30/20. it will be super flush with the fender, and if you can try see if a shop would let you test fit that size first.
Old Nov 5, 2012 | 02:50 PM
Thanks Sunny G, after I posted this I found this thread and looks like I should be in luck (also has some of your helpful replies ), especially since my back wheel's a half inch narrower than the 10.5" in this thread
BTW, I lowered my coilovers to 26.2" to the F&R fender lips and have camber arms/toe kit
https://www.myg37.com/forums/brakes-...-my-sedan.html
2012G37
Jun 3, 2018 06:59 PM
RYs06MT
Apr 22, 2016 11:00 AM
si_driver
Sep 13, 2015 12:04 PM
mmnjtwa
Sep 7, 2015 02:27 PM
OldG37
Sep 6, 2015 10:38 PM
