where to buy a wheel 10mmspacer with bulitin studs
can i a run a +25 in the front on a 20x8.5 wheel?
want to match my rear wheels,can i run +25 in the front on a20x8.5 wheel?
my rear wheels are +37
**CHANGED MY QESTION**
i have a sedan lowered on eibachs
Mr. Drop it like it's hot
The project kics are advertised with built in studs.
https://www.myg37.com/forums/wheel-a...-in-stock.html
I did a minor search of 10mm with built in studs and saw multiple people having problems with the spacer failing on them. Might be because 10mm just isn't thick enough to support the stud. I'd just either run extended wheel studs and 10mm for that size. Or bump it up to 15mm spacer with built in studs which are a lot more common.
I've only seen Project Kics make 10mm spacer with built in studs, no other company. Like others mentioned, it's because the spacer is thin and there is barely any metal to hold the stud in place, not sure how strong it would be.
Also for Project Kics, you must buy the hubcentric rings separately that are made by project kics, they slide into the spacer
WillCo1
Aug 25, 2015 02:25 PM
