Why is there a 6th stud on the front wheels?
Old Oct 7, 2012 | 10:34 AM
zokissima's Avatar
zokissima
Hi guys,
So after starting some threads, and calling around, I decided to go and just try some wheels to see what would work for a winter setup. When I pulled off the front wheel off my G, I saw that there are the 5 normal studs that hold the wheel in place, and there is a 6th, shorter, stud that kind of just slots into the stock wheel.....what the hell is that? I've never seen that before, and why is it there? How the heck do you fit aftermarket wheels onto this car then? You need brand new studs and bolts, and you need to shear that 6th one off or what?
Old Oct 7, 2012 | 10:41 AM
dkmesa350z's Avatar
dkmesa350z
To prevent you from installing stock rear wheels on the front. Needs to be removed for most aftermarket wheel installation.
Old Oct 7, 2012 | 10:44 AM
Tazicon's Avatar
Tazicon
Originally Posted by zokissima
Hi guys,
That bolt, can be taken off. It serves a pupose though. If you remove that little bolt, then remove the spacer off the bolt, then run the bolt back into the rotor, it will help "pop" it off. Sometimes rotors get kind of stuck on and this bolt helps with removal. You dont "have" to have it there. Most rotors just have the threaded hole instead. Yesterday when I did my rotors I was glad it was in as it kept the threaded hole from rusting and making it unuseable. The choice is yours but I put mine back into place.
Old Oct 7, 2012 | 12:08 PM
zokissima's Avatar
zokissima
Ok, thanks guys. Yep, I know that the rotors can get stuck. I used to have to drill holes in my previous car to get them off.
Since I was at a shop that wasn't mine, and had only a few minutes to try a rim, i couldn't get a closer look, but how do you take that bolt off?
Mostly I was looking to get it off in order to be able to fit smaller wheels for winter. Maybe I can use silicone sealant to seal the hole after it's taken out.
Old Oct 7, 2012 | 02:48 PM
Atlbrav1's Avatar
Atlbrav1
I wondered the same as you when i went to try different wheels. "Whats this odd extra nut for?". Both the above answers make sense. Not sure if the size varies by year or not. I have a 2008 and it was a 12mm socket that did the trick for me to get that little bolt off... Good luck with your winter wheel choice.
Old Oct 7, 2012 | 03:41 PM
ashmostro's Avatar
ashmostro
umm, with a socket wrench? You aren't even likely to need an impact. It's not that hard.
SBG37
May 5, 2022 10:35 AM
xstarpro
Jan 19, 2016 07:15 PM
news1213
Dec 16, 2015 11:06 AM
james6980
Oct 9, 2015 01:28 PM
ddayeg37s
Aug 9, 2015 07:10 PM
