Sport Calipers Fit non Sport Rotors?
Old Sep 8, 2012 | 09:44 PM
Abramite's Avatar
Abramite
I have an 09x coupe, If I buy Sport front and rear calipers will they mount on non sport Rotors? Are the Bolt patterns the same on the calipers. Tried searching and couldn't find anything.
Thanks,
Old Sep 8, 2012 | 09:52 PM
LexiG37's Avatar
LexiG37
Check an online parts distributor. You'll find that rotor sizes are different for the S and the non-sport. So sport calipers will need sport spec rotors.
Old Sep 9, 2012 | 06:42 PM
Abramite's Avatar
Abramite
I know the rotors are different sizes, but what I'm wondering is if I can bolt a Sport Front Caliper in place of my existing. Are the sport pads / contact surface, wider than the non sport pads?
Old Sep 9, 2012 | 07:14 PM
soundmike's Avatar
soundmike
Not only that, but they're also further out. You'll get a lot of pad overhang.
Get the rotors while you're at it, it's not that much more.
Old Sep 9, 2012 | 07:56 PM
Rad_Slinger's Avatar
Rad_Slinger
The sport calipers bracket is different. Mike is correct, you will have pad overhang if you use the standard rotors.
You need to get the larger diameter rotors to go along with the sport calipers.
Honestly, why take the chance. These are your brakes we're talking about here....don't skimp on cost.
Old Sep 10, 2012 | 06:14 PM
Abramite's Avatar
Abramite
So if I get Sport rotors and calipers it's a direct swap? No caliper carrier or anything like that needed? I would purchase hardware though.
Old Sep 10, 2012 | 06:17 PM
You'll need calipers, rotors, and brake lines to do the swap.
ck1109
Oct 20, 2015 03:34 PM
dwhit757
Oct 12, 2015 04:27 AM
TheLocNar
Aug 16, 2015 07:14 PM
