Nissan GTR tires into G37 (rear)
Old Jun 8, 2012 | 03:54 PM
amigo916's Avatar
amigo916
Smile Nissan GTR tires into G37 (rear)
Ok . well im a totally @ noOb on understanding tire fitments and the flush style that make cars loOk wider in the rear.
An opinion/Answer to my question will help ALOT! from someone with experience in tire fitment or anyone that has maybe try it before*
i have the CV3's on my G with 285/30zr20 on the Rear*
Lowered on eibach sport springs*
I want a wider and lil bit bigger loOk on the rear so i bought this size of tires
285/35zrF20 which belongs frm a GTR.obviously the tires are bigger.
the only thing i know is im gonna need to roll the fenders and maybe get spacers toO.
question is will this be OK?
thanks and appreciate the input.
Old Jun 8, 2012 | 04:10 PM
G37Sam's Avatar
G37Sam
Why do you want to go larger overall and screw your speedo? Car might look weird if you ask me.
Old Jun 8, 2012 | 04:27 PM
amigo916's Avatar
amigo916
i just wanna go a lil bit more bigger on the rear tires .
for me i think it might loOk ok maybe the CV3;s wont give me the lOok i want so i probably switch to something w/ deep lip.
how would screw my speedo? srry for my ignorance
Old Jun 8, 2012 | 04:33 PM
ECain18's Avatar
ECain18
Ur going with a wider tire but taller tire as well. 285(wide) and 25 (tall). You have to keep the same overall ratio so ur sidewall of 20 would probably be more correct for the wider wheel. If you go with too high of a sidewall itll mess with the vdc and speedo because it would be out of the stock range of parameters is what sam is getting at
Old Jun 8, 2012 | 04:34 PM
ECain18's Avatar
ECain18
Are u trying wider or taller? What do u mean by bigger?
Old Jun 8, 2012 | 04:44 PM
amigo916's Avatar
amigo916
thanks for the explanation really helpful !
well it loOks like both
i will try get a pic
Old Jun 8, 2012 | 05:13 PM
amigo916's Avatar
amigo916
[IMG][/IMG]
why do i wanna do this ? i got the idea frm this i like the way ithe tire sticks out on the rear (my opinion) so i want to get something close to that.
Old Jun 8, 2012 | 05:19 PM
ZOSTER33's Avatar
ZOSTER33
OP has stated that he wants a wider tire but already has a 285/30-20 and wants to upgrade to a 285/35-20?
Am I missing something here or are both tire sizes the same width with the latter being taller?
Old Jun 8, 2012 | 05:22 PM
ZOSTER33's Avatar
ZOSTER33
Originally Posted by amigo916
[IMG][/IMG]
So get spacers and push the wheel out some. What are your offsets now?
Old Jun 8, 2012 | 05:27 PM
amigo916's Avatar
amigo916
thats the problem i have. i need to do more reading about tire fitment and offset im kinda behind on.
what i can tell you is the front tires are 245/35/20 rear 285/30/20 hankook like most members in here.
Old Jun 8, 2012 | 05:45 PM
ReddieG37's Avatar
ReddieG37
you would have to go lower offset wheels or get spacers to push the wheels out. getting a bigger sidewall won't do much except make the tires "taller" and cause incorrect readings on your speedometer.
Old Jun 8, 2012 | 05:50 PM
Kidcane's Avatar
Kidcane
Florida G Club
It really wont make much difference. I am on a 275/35 and it is just a little beefier side wall. My speedo is still within 1 mph at about 45.
Old Jun 8, 2012 | 05:59 PM
amigo916's Avatar
amigo916
(FantastikG37) ooh ok . . got it , got it well there will be any problems if i do that?
(Kidcane) thanks for sharing *
Old Jun 8, 2012 | 06:21 PM
amigo916's Avatar
amigo916
well fellas , im gonna be the practice this time and see how this comes out what bads will show or Not.
but thanks for the input and reading my thread.
Old Jun 8, 2012 | 06:34 PM
ZOSTER33's Avatar
ZOSTER33
Changing the tire alone will not give you the look you are looking for. Spacer bro...5mm or 10mm....you'll have to play with it so you can achieve that look on the 240sx but then you may need a camber kit and run a stretched tire?
G37xhibeet
Nov 15, 2016 09:29 AM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
jayrdong
Oct 25, 2015 10:00 PM
dAgent
Aug 19, 2015 06:49 PM
ddayeg37s
Aug 9, 2015 07:10 PM
