BC Racing BR-Type too stiff?
Old Feb 19, 2012 | 06:13 PM
audtatious's Avatar
audtatious
Anyone running BC's on a G37 and find them simply too stiff? 2008 S-coupe with V-02 kit, preload has been set as per BC tutorials and others. Rear damping is set to 30 (softest) and front is 10. I've had multiple people take a look for any issues with the installation and it checks out. On semi-smooth roads, no issue. Get any bumps or transitions and they can be very harsh. Problem primarily seems to be the rear. I also have Hotchkis sway bars set to middle setting in rear.
Took a ride in a G35 sedan with BC BR-Types (D-17) and it was night and day. Where my car would hop, his ate the bumps (Shocks are set at 10/10). The system seemed to work great over the same roads. He checked my setup as well and didn't find any issues. When driving my car he noted how harsh it was as well.
So, V-02 is 12k/10k and his D-17 is 10k/8k. Wheelbase of both vehicles are the same. Coupe is just a tad over 200lbs heavier.....Is it possible to use 10k/8k springs on the V-02? Anyone else experience this problem and resolve it?
Old Feb 20, 2012 | 12:38 AM
Tunerz_Store's Avatar
Tunerz_Store
Parts Specialist
I would also like to hear feedback from others running the BC's....
Old Feb 20, 2012 | 01:00 AM
v.b's Avatar
v.b
Not sure what the BC tutorials tell you, but set your preload to 0. That will make it absorb bumps a bit better. I run 0 preload all around on my stance coilovers. You don't want to be preloading progressive springs if you want comfort.
Old Feb 20, 2012 | 02:38 AM
Tunerz_Store
Parts Specialist
The information you are referring to is the dampening of the shock, not the preload of the spring for installation, especially in the rear.
Old Feb 20, 2012 | 06:14 AM
v.b's Avatar
v.b
The information you are referring to is the damping of the shocks, not dampening.
The "preload" of the spring is not only used for "installation" and it can also be adjusted independently from damping. Preload adjustments can be made in order to modify the handling dynamics of the suspension.
Old Feb 20, 2012 | 06:58 AM
audtatious's Avatar
audtatious
Per instructions, when the suspension has no load (off ground, no shock connected) you raise the rear lower link until you can no longer turn the spring. Then, raise it up an additional 10mm to set proper preload and attach the shock.
If removing the preload from the rear springs is the answer then that's fine. I'm not sure a simple 10mm change is going to have that much effect with how stiff the ride currently is, progressive rates or not.
Right now I have the rear at appx a .5" drop which means removing preload would probably not result in any major issues. If the vehicle was 1"+ lower then removing preload could result in a loose spring at full suspension travel, correct? I'll have to think about that more...it's too early
Old Feb 20, 2012 | 11:59 AM
Tazicon's Avatar
Tazicon
G37 Sedan: 2012 Infiniti G25 and G37 Sedan Specs and Options | Infiniti USA Official Site
G37 Coupe: 2012 Infiniti G37 Coupe Specs and Options | Infiniti USA Official Site
I am not sure where people get their info on the weight difference between a coupe and sedan
Old Feb 20, 2012 | 12:07 PM
pauliewalnutzz's Avatar
pauliewalnutzz
I remember Betting making some topic saying, "Its damping not dampening" lmaoo
Old Feb 20, 2012 | 12:54 PM
Coprolite's Avatar
Coprolite
I think he was comparing G35 Sedan and G37 Coupe.....
Old Feb 20, 2012 | 06:16 PM
v.b's Avatar
v.b
Your springs won't go anywhere. Just remove those additional 10mm and see if your ride improves...
Old Feb 20, 2012 | 06:54 PM
audtatious's Avatar
audtatious
As previously stated I was comparing the '04 sedan and '08 coupe. I thought that was clear, maybe not...
Old Feb 20, 2012 | 06:56 PM
audtatious's Avatar
audtatious
That or just go ahead and order the 10/8's and be done with it
Thanks!
Old Feb 20, 2012 | 08:13 PM
BlkG-37S's Avatar
BlkG-37S
Should have gone with Tanabes..
Kojack
Oct 9, 2015 05:53 PM
chris_s
Sep 8, 2015 03:37 PM
