Help Alignment Specs
Old Sep 24, 2011 | 05:15 PM
jsingh's Avatar
jsingh
Alignment Specs
I need some advice, these are the specs of the alignment I had done. I don't have a camber kit and I don't plan on buying one since I'll only have the vehicle for 6-8 months. Just changed my tires out due to excessive inner tire wear (30K KM driven). Can someone please tell me if the specs are okay? Thanks.
Old Sep 25, 2011 | 01:58 PM
Philip8969's Avatar
Philip8969
Not bad. I mean obviously there is a little more negative camber in the front than would be ideal, but I wouldn't worry about it. Those numbers fall into what I would call a performance alignment range. What Eibachs are you running and what tires did you just get rid of? How long did you have it dropped on those tires?
Old Sep 25, 2011 | 03:27 PM
jsingh's Avatar
jsingh
Eibach Pro-kit (Coupe), ran an alignment soon after I lowered it with stock wheels/tires. Then again when I put the 20" Vossens on w 235/30 and 255/30 Hankook V12's.
Had the Vossens on since May '10 (not winter driven). Just put new tires on 235/30 and 255/30 Falken FK452's.
Old Sep 25, 2011 | 06:33 PM
Philip8969's Avatar
Philip8969
If you got 30K on the Hankooks I wouldn't worry bout making any more changes. Especially if your only going to have the car another 6 - 8 months. Should be fine.
philttz
Oct 13, 2015 08:59 PM
rk325
Oct 13, 2015 01:51 PM
faze2988
Oct 7, 2015 12:05 AM
Murkr
Sep 28, 2015 10:45 AM
m3clubracer
13
Sep 28, 2015 09:54 AM
