Dash lights on ABS/SLIP/VDC/BRAKES
Old Jul 9, 2011 | 08:44 PM
Danjjacob's Avatar
Danjjacob
I just had my rear tires replaced and went from 275/30 (too small OD) to 255/40 (0.3" larger OD than stock) and now the dash lights up like a christmas tree. Lights come on after driving about 1/2 mile. I called the dealer service and they didn't think it would have anything to do with the tire swap. I have changed tires before, snow tires are 225/45 all around, and the lights didn't come on.
Anyone know what might be going on? Thanks for any input.
Old Jul 9, 2011 | 11:19 PM
mystakin's Avatar
mystakin
is it every light? or specific ones? even things not related to the tires? (like a check engine light or something..)
Old Jul 9, 2011 | 11:35 PM
dal1307's Avatar
dal1307
Dan,
If it is the ABS/SLIP/VDC/BRAKES lights that are on then I would suspect low brake fluid. Any leaking in the garage? Check the bake fluid level first if you have not already.
Old Jul 9, 2011 | 11:41 PM
Z gave way to G's Avatar
Z gave way to G
I would check wheels speed/ ABS sensors. May have been disconnected or damaged. All those lights described can come on due to sensor malfunction. Good luck
Old Jul 10, 2011 | 11:05 AM
Danjjacob's Avatar
Danjjacob
Thanks guys, where are the rear ABS sensors?
Old Jul 10, 2011 | 11:25 AM
beerme986's Avatar
beerme986
The only thing that changed on your car was the tires so that seems like the problem. Also. I had the same exact problem as you when I tried to go different tire sizing. The car thinks the front and rear wheels are rotating at different speeds now so the abs lights and traction control are kicking in
Old Jul 10, 2011 | 12:40 PM
Danjjacob's Avatar
Danjjacob
It is just the lights listed in the thread title. When the wheels were off I looked on both sides for anything loose or broken and didn't see anything out of the norm. Do the TPMS sensors inside the wheels have any other function other than TPMS (the TPMS light is not on)?
Old Jul 10, 2011 | 10:44 PM
Djfarhan's Avatar
Djfarhan
Urgent input/advice needed on e-brake-vdc-slip-cruise lights coming on! - G35Driver
Old Jul 12, 2011 | 06:20 PM
Danjjacob's Avatar
Danjjacob
Here is the latest,
Took it into the dealer and they topped up the brake fluid and said the front pads were 7 mm and the rears 5 mm, both ok for now. They thought topping off the fluid would take care of it. Lights came back on 1/2 mile from the dealership. Taking it back in tomorrow. I'll keep you posted.
Old Jul 12, 2011 | 08:04 PM
beerme986's Avatar
beerme986
I can almost guarantee it's your tire sizing throwing the wheels sensors off ....
Old Jul 22, 2011 | 11:21 PM
Danjjacob's Avatar
Danjjacob
After having it at the dealer for 1 1/2 weeks where they replaced the ABS control module and something else, I picked the car up today. 1/2 mile from the dealership the lights are back on. I am going to try to get the tires exchanged for different size. Why would smaller diameter but wider tires be ok but slightly larger diameter set off the works?
Old Jul 24, 2011 | 05:11 PM
beerme986's Avatar
beerme986
"275/30 (too small OD) to 255/40 (0.3" larger OD than stock"
your rears are smaller and rotating faster, the fronts are larger rotating slower. the car computer is goings nuts as it thinks your car is slipping as the sensors arent reading as they should.
the sizing most people on with no issues seems to be 245/40-19's on the front and 275/35-19's on the back
..i had the same issue with you when I got different tire sizes on. if you dont feel comfortable playing with sizes, get OEM sizes. many tires available now that fit our car
Old Jul 24, 2011 | 11:34 PM
Danjjacob's Avatar
Danjjacob
That's exactly what the problem was. I swapped rears for 275/35 and lights did not come on. Thanks guys.
604gz
Sep 22, 2015 08:42 AM
pcwd
Sep 15, 2015 10:06 PM
CasperG37
Sep 14, 2015 07:46 PM
B Feelgood
Sep 13, 2015 05:56 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
