VDC, SLIP, Brake Light...and what dealer has to say
Old May 1, 2011 | 03:42 PM
sunnd204's Avatar
sunnd204
Car: 2008 Infiniti G37 Sport - 34,489 MILES
Issue: VDC, Slip, Brake Light turn on. Also Rust on the trunk.
Situation: Took it to the dealer and here is a summary of the events:
Told dealer which lights came on. He checked the brake fluid and said most likely it was time to replace pads (Not covered under warranty).
In regards to the rust on the trunk; dealership said it was due to the alignment of the trunk causing paint to scratch off and will need to be repainted and realigned (covered under warranty).
After a few hours here is what the dealer recommended along with the cost in Canadian Dollars:
Replace front/rear pads and rotors: $1100
-The worn out brakes caused fluid level to go down and it turns on dash lights.
New Tires:
-New rear tires $950
Replace Air Filters: $80.00
New Steering Fluid (they found it to be dirty and contaminated): $139.95
Total recommended changes cost: $2710
I think I will replace the pads and filter myself and get a second opinion on the rotors. Not sure about the steering fluid. What do you guys think?
Old May 1, 2011 | 04:13 PM
kosstick's Avatar
kosstick
You can replace the Front and Rear pads and rotors for Way lees than half. Rear tires for $950? $475 each? Wtf they putting on Michelin Pilot Sport Cup plus lolll.
Tell them to go **** themselves.
Old May 1, 2011 | 05:56 PM
Ken's Avatar
Ken
$950 for rear tires is ridiculous. $80 for air filters is ridiculous. See if you can get the rotors machined not at the dealer. Pads can be changed easily yourself.
Old May 1, 2011 | 06:42 PM
Steveo47's Avatar
Steveo47
for 900 dollars for rear times, you better be getting some crazy street legal F1 tires that never wear out. 900-1100 is the range for a brand new set of 4 of s drives or something. For 1100 dollars you could buy 2 piece front, some nice stoptech backs, and a all 8 pads (okay may more like 1400 but if your paying 1100 already, you may as well do it.
Old May 1, 2011 | 07:25 PM
sunnd204's Avatar
sunnd204
Time to attempt a brake pad DIY
I agree, I am thinking of replacing the pads myself.
The car is a daily driver so I was thinking Wagner Thermo Quiet should be good.
Old May 3, 2011 | 01:38 AM
ozzypriest's Avatar
ozzypriest
oh my God - what a huge ripoff. I was going to replace my front pads (hawk ceramics) and rotors (Centric) for like 350 from my dealer. 230 for parts, 110 for labor. You can t great tires for 700 or all the way around form tirerack. You can do air filters for 20 or so, Steering fluid for like 40-50 tops? They are crazy.
Old May 4, 2011 | 04:41 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
everything cost more in Canada!!! lol
theKfactor
Sep 12, 2015 09:35 AM
T_Buckets_223
Sep 8, 2015 09:49 PM
inspector94
Sep 8, 2015 12:57 PM
ZachThomas
Sep 3, 2015 01:40 PM
