Increased vibration in steering wheel after installing wider front wheels
Old Apr 26, 2011 | 01:29 PM
redrover23's Avatar
redrover23
I recently installed 20x9.5 (F) and 20x10.5 (R) aftermarket wheels on my G. I noticed increased vibration in the steering wheel after. I got my car aligned about a month prior to upgrading the wheels. Has anybody experienced this?
Should I redo the alignment with the new wheels on?
TIA.
Old Apr 26, 2011 | 01:32 PM
Weiboy718's Avatar
Weiboy718
TIA.
FIrst off:
What kind of wheels
Did they balanced it correctly
DO you have the hubcentric rings
Are the tires good.
Old Apr 26, 2011 | 01:33 PM
P Casey's Avatar
P Casey
vibration usually mean tire balance is off
Old Apr 26, 2011 | 01:36 PM
redrover23's Avatar
redrover23
FIrst off:
What kind of wheels
Are the tires good.
Thanks for reply.
GT30
Assumed to be balanced correctly. Mounted at a import tuning place in SD (that has been around for a while).
Rings are installed 66.1
Tires are new Vred Sessantas 245/35 and 275/30
Old Apr 26, 2011 | 01:49 PM
redrover23's Avatar
redrover23
This is probably the case. I hate rework, especially when you pay someone to do the work. Straight BS.
Old Apr 26, 2011 | 01:53 PM
redrover23's Avatar
redrover23
One thing I did find interesting is: the hub rings can be pushed in deeper than the contact surface of the wheel. In other words, the deeper they are pushed in, the less engagement with the hub. How do you guys set your rings? Pushed all the way in? Or flush with the seating surface?
TIA.
Old Apr 26, 2011 | 02:08 PM
Weiboy718's Avatar
Weiboy718
since it's Volks, Try running them without the hubrings. I didn't need the rings when I was using my friends gt30's no vibration whatsoever
Old Apr 26, 2011 | 02:18 PM
GraphiteG37S's Avatar
GraphiteG37S
^ It's worth a shot. But it could be the balance (unless of course a wheel is bent).. On my Volks I always just push my hub rings all the way into the wheels then mount the wheel on to the hub and secure the lugs. Never had any vibration.
Old Apr 26, 2011 | 02:23 PM
redrover23's Avatar
redrover23
Thanks for the replies.
I'll cruise later and see how bad it is. It's more like a shiver in the steering wheel.
Old Apr 26, 2011 | 02:35 PM
GraphiteG37S
^ Were you running stocks before? You may feel more of the road now when driving with the wider wheels and lower profile tire.
Old Apr 26, 2011 | 02:41 PM
redrover23's Avatar
redrover23
^yes. That came to mind so that is why I posted it. I thought (since many forum members are on aftermarket wheels) members may have experienced the same. I should try to find a relatively smooth road to further evaluate.
Old Apr 26, 2011 | 03:16 PM
da mayor's Avatar
da mayor
try to do another balance on teh wheels... it wont hurt
Old Apr 27, 2011 | 07:53 PM
Djfarhan's Avatar
Djfarhan
post pics!
Old Apr 27, 2011 | 09:11 PM
bukg37's Avatar
bukg37
just install my gt30 from (weiboy/joey) last week w/o a hubrings, didnt feel a thing at 100mph , i think we have the same offset 35 / 37 .
Old Apr 27, 2011 | 09:44 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
subscribed
