Noob qustion about rims/fitment
Old Apr 5, 2011 | 06:04 PM
kovac21's Avatar
kovac21
Exclamation Noob qustion about rims/fitment
I have a 2008 G37s coupe, I'm looking at buying Vossen VVS082 082 Black/Machined or Vossen VVS086 086 Matte Silver both are (R)20x10.5 (F)20x9 basically in a sense they are the same.
Now, Ive been searching to see what sort of things other people have been doing but all I'm reading is about camber kits and things like that. Some people say you do need them and some say you can go without them. I really don't understand what camber kits do because its out of my area of expertise so sue me haha.
Along with the rims i would also purchase some sort of lowering spring. What brand i haven't look in yet. With springs all i want is to fill the gap between the tire and the fenders but not so much that it will rub. If any one has a set like what i just have described let me no i would appreciate it.
To get back on the rims what sort of offset would be best to run so the rims are flush with the fender and have the biggest lip on the rear? On the front i would only like them to be flush, not to picky on the lip size with the fronts.
Thank you all.
Old Apr 5, 2011 | 06:09 PM
Weiboy718's Avatar
Weiboy718
Sounds like the eibach pro kit will fit you best. It has a minimal drop where it'll close the wheel gaps. With this drop you may get away from using a camber kit although it's still recommended. As you lower a car your wheels will become like this / \ that's why you need a camber to straightened that up or your tires will wear out unevenly
Old Apr 5, 2011 | 06:28 PM
kovac21's Avatar
kovac21
With the eibach pro kit would i have to roll the fenders just in case? Or what?
Old Apr 5, 2011 | 06:32 PM
P Casey's Avatar
P Casey
NO fenders are already rolled.
Old Apr 6, 2011 | 08:35 PM
droogie's Avatar
droogie
I'm not sure which offsets to go with, but call Vossen and ask to speak with Jav, he will set you straight. You are right, you absolutely need lowering springs if you want it to look good. As you lower a car, the camber naturally increases. The stock camber adjustment does not have enough range to correct for this, hence new camber arms may be required. With Eibach, you don't need a camber kit. If you go to a good alignment shop, they will be able to get it pretty close to spec. For my car, they got it to what they called a "performance alignment" which is probably what they would have done anyway (I got it aligned at a road race shop).
Old Apr 8, 2011 | 02:27 PM
Mike@Vossen's Avatar
Mike@Vossen
SUPPORT AUTHENTICITY!
Please contact us and we'll take care of you.
Vossen Wheels
What it comes down to is, as long as you don't run really THICK tires you'll be good to go! Once you get everything mounted on you can always go and get your camber aligned. I highly doubt that with a subtle drop you'll need any camber kits.
Old Apr 8, 2011 | 03:03 PM
myk1013's Avatar
myk1013
Go with Eibach Pro-Kit springs....
-gets rid of fender gap (with 20" wheels)
-maintains a similar ride quality as the oem sport springs.
-you shouldnt have any problem with rubbing if you get the recommended tire specs.
Old Apr 8, 2011 | 03:55 PM
A_Palaroan's Avatar
A_Palaroan
Im dropped on eibach with vossen 082 with my rear offset at 35 and front offset at 25 with no rubbing at all. i also have hankook v12's 285/30/20 and 245/35/20. these are the perfect size with no rubbing
Old Apr 8, 2011 | 03:57 PM
A_Palaroan's Avatar
A_Palaroan
check out my thread. this is before the springs settled.
https://www.myg37.com/forums/vendor-...torsports.html
G37xhibeet
Picture Share G Coupe
Jun 21, 2017 02:38 PM
rk325
Oct 13, 2015 01:51 PM
Simm0nS777
Sep 24, 2015 08:19 PM
Simran Mann
Sep 13, 2015 01:51 AM
jakebeefsteak
Aug 14, 2015 10:23 AM
