questions for eibach sway bars
Old Feb 25, 2011 | 01:52 PM
matty G's Avatar
matty G
I have a g coupe does anyone know if I have to take my exhaust out in order to put on my eibach sway bars I have both front and rear, thanks. ??
Old Feb 25, 2011 | 03:26 PM
TVPostSound's Avatar
TVPostSound
All you need to do is disconnect the muffle at the axle, and remove the middle crossbrace.
Eibach has a DYI on their site.
Old Feb 25, 2011 | 03:38 PM
Presto's Avatar
Presto
does the eibach sways clear all aftermarket exhausts? i think i read a post here that said it touched the FI exhaust?
what about cars equipped with 4was?
Old Feb 25, 2011 | 05:58 PM
Loi's Avatar
Loi
I've installed the stillen sways but all you have to do is unbolt the hinges before the axleback so it drops about an inch then wiggle the sway bar in.
Old Feb 25, 2011 | 06:08 PM
Steveo47's Avatar
Steveo47
its very easy, four exhaust bolts + 2 smalled ones for the brackets to pull it down. No stress involved
Old Feb 26, 2011 | 05:42 PM
joo030879's Avatar
joo030879
Eibach are mm's thicker not inches. You have enough clearance. Don't worry. They are the easiest DIY under the car.
Old Feb 27, 2011 | 01:10 AM
rskip's Avatar
rskip
Just did the upgrade today and can confirm on the stock exhaust that you only need to take out the 4 exhaust nuts and the 2 nuts holding the brackets a foot or two ahead of the exhaust flanges. No need to remove the brace as per hotchkis instructions. It did help me to lube the rubber muffler mounts so i could scoot the muffler towards the back to gain more clearance between the muffler and the rest of the exhaust. I actually had more problems with the fronts due to a stubborn bolt and lack of space (no lift - only about a 3" makeshift ramp).
-rskip
Old Feb 27, 2011 | 06:05 AM
AussieV36's Avatar
AussieV36
I've got eibachs on a coupe with 4was
no problems at all, as someone had said the difference between stock swaybars & eibachs is mm
hands down the best mod for handling you can do, what a night & day difference
kavcheung
Jan 22, 2016 02:40 PM
Feffman
Upcoming Events
Oct 8, 2015 08:16 AM
Mattlorentzoe
Sep 14, 2015 07:32 PM
EnYcee-G
Sep 3, 2015 04:35 PM
Andyg90
Sep 2, 2015 06:10 PM
