Help Work T1S
Work T1S
Looking at getting some new wheels for this upcoming spring.
2008 Liquid Platinum G37S Coupe
Work T1S Varianza 20"
20 x 9.5 + 35 Front
20 x 10.5 + 37 Rear
LS or MSP - Which Color?
Thoughts on offsets?
Thoughts on rubber?
Work Wheels
Products
Varianza T1S
20 x 9.5 + 35 Front
20 x 10.5 + 37 Rear
Thoughts on rubber?
Work Wheels
Products
Varianza T1S
Color: they're pretty close, both looks good.
Offsets: The rear offsets are fine but then front are a little too conservative. around +25 would be better. But if you're riding sotck height or mild drop, those offsets are perfect.
Rubber: as for size, with +35/+37 you'd be going with 245/35 275/30, or 255/35 285/30 with minor fender modifications.
Sena, haven't heard from you in a while bro.
As for tires, definately go 245/35 and 275/30. Depending on how low you are(i'm completely slammed) you have to be careful on what brand tires. Ex. Hankooks are a little bit more square then say Toyo T1R's.
As for the Finish, the polish will look closer to a chrome finish when "CLEAN", but the silver itself will probably be easier to keep clean.
As for the Works...just remember there's a 3-4 month wait out to receive them....
Nice, i was going with T1S too, but changed my mind after test fitting it. Cause it seems too.. 'clean' for me, like its not aggressive enough, but i think if i test fitted with the step lip, it would be a different story.
https://www.myg37.com/forums/picture...ianza-t1s.html
My offsets were on the conservative side, but here's how MSP would look on a LP.
