Bc coilover question on install
Old Nov 4, 2010 | 10:32 AM
jarena2104's Avatar
jarena2104
I installed the BC coilovers and i noticed on some posts that people are using the rubber cones with the spring, i dont have that installed and was wondering if this was the problem, anyones help would be appreciated please
Old Nov 4, 2010 | 10:53 AM
Weiboy718's Avatar
Weiboy718
Think about this, if you installed the rubber cone you won't be able to adjust your height.
Those older threads you looked at probably installed it upside down. Your clunking sound is most likely coming from your rear shock mount. You can try to remove your stock one and install it on your BC. That might help dampen that sound more
Old Nov 4, 2010 | 12:13 PM
Kidcane's Avatar
Kidcane
Florida G Club
Why would the rubber cone keep you from adjusting your height? You just want be able to go quite as low but I dont know why you would want it to sit on the ground anyway.
Old Nov 4, 2010 | 12:46 PM
Weiboy718's Avatar
Weiboy718
Because the rubber cone sit's on top of the spring perch, so please explain to me how is he going to mount the spring adjuster
Old Nov 4, 2010 | 02:32 PM
Kidcane's Avatar
Kidcane
Florida G Club
Sorry my bad, I meant the lower rubber isolater. That stays, rubber cone is NOT used. Carry on!
Old Nov 7, 2010 | 08:36 AM
use2vw's Avatar
use2vw
If you want to sell your rear top rubber cones...I'd buy them ASAP...I'm looking to do the "springmount shave" slight drop to my 37x sedan...PM me- asap
Old Nov 7, 2010 | 10:13 PM
droogie's Avatar
droogie
So these BC coilover's clunk and squeak? They looked real attractive but its simply unreal that you would spend over 1 grand on coilovers and have them not be totally quiet.
Old Nov 7, 2010 | 10:18 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
They are not needed, nor would they fit when using coilovers
Old Nov 7, 2010 | 11:02 PM
platinumg35x's Avatar
platinumg35x
didn't the coils come with instructions?
Old Nov 11, 2010 | 05:22 AM
w0ady's Avatar
w0ady
i have no noise issues with mine. nor do a lot of people. relax.
Old Dec 4, 2010 | 12:38 PM
symple84's Avatar
symple84
I know this is an old thread, but for those of you who installed the BC coils - did you pass the rear extenders into the trunk like the directions stated????
Old Dec 5, 2010 | 08:00 AM
jarena2104's Avatar
jarena2104
i got a hold of pete at BC he was really helpful. i gotta go drive to jersey to let this guy check it out there might be to much preload on the rear struts causing it to hit hard on a bump even on the softest setting. ill post up the review after it gets done
Old Dec 5, 2010 | 11:15 AM
Kidcane's Avatar
Kidcane
Florida G Club
Mine are run through in to the trunk.
Old Dec 25, 2010 | 12:54 AM
jmlenz's Avatar
jmlenz
Did you get this figured out? I had the same problems with my Megans on my 370z. It made a clunking noise in the rear on hard bumps. Adjusted pre-load, was not using lower rubber isolator, installed correctly and stil lmade noise. Pissed me off.
Old Jan 8, 2011 | 09:07 PM
bsowhat1's Avatar
bsowhat1
I believe BC is shipping a rubber isolator for the rear spring assembly to prevent the noise issues.
