SPC or Eibach camber kit?
Old Apr 28, 2012 | 03:12 PM
  #31
noloveg37's Avatar
noloveg37
Yeah....I guess I'm a little off. When I get home I'll post my spec sheet. Thanks for that.
Old Apr 28, 2012 | 05:18 PM
  #32
soundmike's Avatar
soundmike
Originally Posted by joo030879
actually it is not the rivised one you want. SPC did release a different version for G37. However soon found out one they had been selling for G35 is also better for G37. So even if someone wanted to purchase newer version created for G37. SPC abandoned the newer version for G37. And ones sold were voluntarily recalled.
Would you happen to have a pic or part # that shows the difference? I'm planning to finally install mine and would like to check which version i have before doing so.
Thank you.
Old Apr 28, 2012 | 05:31 PM
  #33
noloveg37's Avatar
noloveg37
Old Apr 28, 2012 | 06:04 PM
  #34
soundmike's Avatar
soundmike
^ Definitely need one, your camber can probably still be tweaked a little, but that toe is seriously out and will chew through your tires fairly fast.
Old Apr 28, 2012 | 06:16 PM
  #35
joo030879's Avatar
joo030879
Originally Posted by noloveg37
Lookin for general commentary here.
Im on OEM front ant back
Front camber -1.9
Rear Left -3.2
Rear Right -2.7
Just got new rear tires and alignment done two days ago.
How bad do I need a camber kit? Do I need both front and back? Thanks
Not bad for the front. But definitely rear kit.
Old May 2, 2012 | 01:44 PM
  #36
noloveg37's Avatar
noloveg37
ok i have another question. Im running pretty DAMN flush. talking about may be 1cm of clearance with the fender. how much correction will even possible to achieve given how flush i am? would the camber kit still be worth it then?
Old May 3, 2012 | 02:00 PM
  #37
SwissCheeseHead's Avatar
SwissCheeseHead
So you are running flush with -1.9 in the front and -3.2 and -2.7 in the rear. Even for those that run hella-flush, I think they are still in spec....so that tells me that your offset might be too aggressive and that getting your alignment back into spec would put you at "mexi-flush" status (where the wheel and tire extend beyond the wheel well).
Do you want to replace your tires every 10K miles due to inner tire camber wear? Do your wheels specs or drop mandate that you run lots of negative camber? A camber kit is $500 now with a DIY. Maybe $700 for parts and labor. A set of tires range from $800-$1500, which would have to be replaced between 7500-15000 miles plus cost of mounting/dismounting/tire disposal etc. I think you can do the math.
Old May 3, 2012 | 03:15 PM
  #38
noloveg37's Avatar
noloveg37
yep
the front i have room to play with, no concern there. the rear however yes im running FLUSH! tire inside the wheel well with 1cm of clearance and that being generous, more like half that. Yes my drop at this time does necessitate the negative camber. offset in the rear is +22. and yes to be in spec im looking at definitely being "mexi-flush." (ive done the math, just installed the rear tires $426 shipped to my door + install/allignment = $575.)Im not concerned about what camber kits would costs, my question is can i even get to within spec without having to say, roll my fenders? you get me?thanks for the insight so far, not my forte here.
Old May 3, 2012 | 03:48 PM
  #39
joo030879's Avatar
joo030879
You should not worry. Unlike front camber kit. For the rear camber is adjusted from below. So instead of pushing top part of wheel out. Alignment will be achieved by pulling in the lower part of the wheel inward. So go ahead and buy the camber kits. Have them installed and re-aligned. As Swiss Cheese says "you will save a bunch on tire".
Don't worry for coupe +22 10.5" is well within range to get it back to factory specs.
Old May 3, 2012 | 04:01 PM
  #40
noloveg37's Avatar
noloveg37
^ thanks guys. (btw its 9.5" if that makes a difference)
Old May 3, 2012 | 04:10 PM
  #41
joo030879's Avatar
joo030879
NP, NO difference
Old May 3, 2012 | 04:25 PM
  #42
joo030879's Avatar
joo030879
By the way i have brand new never installed rear camber kit with toe bolts. Desided not to install them after purchasing them. Because when I take my G37 to racing track -3.1 camber is still not enough camber. And I actually rub the outer part of the wheels more than inner part. Also on street tires I am running 400 UTQG tires. So I decided since I have no issues with tire rubbing. Why bother install them and pay for labor. If you are interested let me know. I paid $156 shipped. I will give you a gift for $100 shipped.
Old May 3, 2012 | 06:28 PM
  #43
noloveg37's Avatar
noloveg37
Joo your the man! PM'ed you already! And thanks for the gift tomorrow's my bday!!!
Old May 3, 2012 | 08:21 PM
  #44
joo030879's Avatar
joo030879
pm replied
jfisher
Apr 25, 2017 01:22 PM
User 122320
Oct 5, 2015 03:03 PM
DiegoMontoya
Sep 22, 2015 11:05 PM
jfisher
Sep 8, 2015 04:16 PM
