Need help with spacer sizes
Old Oct 25, 2010 | 05:15 PM
Doggy's Avatar
Doggy
Hey I want to get a set of spacers front and rear I have stock sport 19s and I want a real aggressive offset, I don't know much about spacers so i need some help on sizes
Old Oct 25, 2010 | 06:58 PM
Felix_the_Cat's Avatar
Felix_the_Cat
I'm guessing your car is lowered since you want spacers... With a drop I'd say 20mm will be perfect for you since you wanna go aggressive 15mm look good too a little less aggressive though.
Old Oct 26, 2010 | 02:27 AM
Doggy's Avatar
Doggy
Right now the cars stock ride but I'm planning on eibach springs I was thinking 25mm, is that too much?
Old Oct 26, 2010 | 02:50 AM
wlmngtn's Avatar
wlmngtn
25mm would be a little too much. Your tires would be sticking out of the fender a little. 20mm would sit just right and flush. SAM has 20mm all around, take a look at his G.
Old Oct 26, 2010 | 12:06 PM
fairladyz34's Avatar
fairladyz34
im selling a set of 25mm ichiba spacers, bolt on ones, if your interested
Old Oct 26, 2010 | 01:11 PM
G_rev's Avatar
G_rev
I went for 20mm FiC spacers ... they're great and looks great with 20mm.
Old Oct 26, 2010 | 01:23 PM
Doggy's Avatar
Doggy
How much?
Old Oct 26, 2010 | 01:26 PM
Doggy's Avatar
Doggy
How do find his car on here?
Old Oct 26, 2010 | 07:57 PM
TVPostSound's Avatar
TVPostSound
20mm looks perfect with Eibach, and stock rims. Im running this set up.
25 too much.
Look at the previous thread "Springs, Sway Bars and Spacers... Oh My!"
Hes got pics of 20mms
Old Oct 26, 2010 | 09:04 PM
edge540's Avatar
edge540
TVPostSound is correct. 20mm does look perfect with the Eibach drop. 25mm would definitely start to stick out.
Here is the link to my post: Springs, Sway Bars and Spacers... Oh My!
Old Oct 26, 2010 | 09:31 PM
Doggy's Avatar
Doggy
ya that looks good, i think thats what im going to do then. how is the ride on the drop?
Old Apr 11, 2011 | 01:25 AM
Infinite.G's Avatar
Infinite.G
Is there a consensus on bolt-on vs. extended studs? Maybe a dumb question... It would seem like a 1-time project of removing calipers and rotors would be worth the state of mind. One less point of failure... and not having to check torque every couple months.
Also, does everybody go same width front and rear... was thinking of 15mm up front and 20mm in the rear. Will that create a noticeable mismatch? I mean we're only talking about 0.2" diffference. Anybody have pictures of 15mm up front w/ Eibach Pro Kit on stock setup?
Old Apr 11, 2011 | 11:01 AM
simpson_G37X's Avatar
simpson_G37X
i have 25mm rears, but then again i have the AWD
nbast
Sep 14, 2015 12:39 PM
si_driver
Sep 13, 2015 12:04 PM
JPat94
Sep 13, 2015 10:35 AM
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
