Which brand of Spacer?
Old Oct 20, 2010 | 03:31 PM
G37SBS's Avatar
G37SBS
Can you guys tell me which brand of spacer do you guys recommend? i heard good things about H&R but how about eibach and ichiba?
Thinking to get Eibach pro kit with 20mm all around but i'm not sure which brand of spacers i should get. Please help me out
btw i'm gonna run with stock 19" G37S rims.
Thanks
Old Oct 20, 2010 | 08:27 PM
TVPostSound's Avatar
TVPostSound
I can only vouch for H&Rs, they are great.
Old Oct 21, 2010 | 03:13 AM
G37SBS's Avatar
G37SBS
i was at H&R website and they have different type of 20mm spacers. One is called DRS and another one is DRM for 20mm spacers. Can someone tell me which one i should get? DRS or DRM?
Thanks
Old Oct 21, 2010 | 10:56 AM
TVPostSound
Here's my theory:
If you are locked into which wheel and tire combo you will live with, then go for the DRS.
If you are like me, lowered with stock wheels, and tires, maybe later on going with a bigger tire, or maybe a different offset wheel.
I will be changing the thickness of the spacers. Then go with the DRM.
Changing spacer thickness, means changing studs for proper length.
I feel that popping out the studs, and replacing them, should happen only once.
More than twice you chance elongating the splined holes in the axle flanges.
Meaning the 3rd time you go to press studs in the axle, they might be loose.
Removing lug nuts when the stud spins (with the wheel on), is a nightmare.
DRMs are very safe as long as you follow the proper torque specs, ans sequence.
Old Oct 21, 2010 | 11:30 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I have Ichiba and they are great. As long as you get hubcentric spacers you should be fine, and no matter the thickness, I would absolutely use longer studs.
Old Oct 21, 2010 | 11:56 AM
LightsOut's Avatar
LightsOut
H&R
I've read Ichibas cause vibrations, due to the centrinc ring being too short.
Old Oct 21, 2010 | 12:01 PM
hispeed-lowdrag
Originally Posted by LightsOut
H&R
I've been over 140 in my G with the spacers installed and no vibrations whatsoever. As long as they are installed correctly there shouldn't be.
Old Oct 21, 2010 | 12:15 PM
jnguyen's Avatar
jnguyen
You're better off with ichiba v2 because it comes with hub ring and built in stud. Most of the hellaflush guys who run spacers all swear by this brand
Old Oct 21, 2010 | 12:18 PM
finagle69's Avatar
finagle69
H&R, Ichiba, Project Kics. They're all fine, with Ichiba being the cheapest.
Quality is as follows:
Project Kics>>H&R>Ichiba
Old Oct 21, 2010 | 12:43 PM
LightsOut's Avatar
LightsOut
many had to do a diy O' ring on the ichibas to get rid of the vibration.
I always went with Ichibas on my g35 coupe. they were very good spacers.
Old Oct 21, 2010 | 12:59 PM
G_rev's Avatar
G_rev
try Fic hubcentric spacers...
FIC Wheel Spacers - More Japan Since 2003
Old Oct 21, 2010 | 06:41 PM
TVPostSound
Yes, but different thicknesses have different length studs, if you are going back and forth with different sizes, you chance ruining your axle flanges.
Then H&R DRMs would be more prudent.
Old Oct 21, 2010 | 07:47 PM
G37SBS's Avatar
G37SBS
Thanks i guess i'll go with DRM
Old Oct 26, 2010 | 01:54 PM
InspiredMan's Avatar
InspiredMan
go with hellaflush branded spacers by Weapon-R, it'll cause thread confusion and calling out by street racers.... epic thread read
Hellaflush spacers?!? - MY350Z.COM Forums
John B
Sep 27, 2015 11:41 PM
kinchi
Sep 25, 2015 12:04 AM
nbast
Sep 14, 2015 12:39 PM
Thirty_Seven
Sep 14, 2015 09:07 AM
drizzy315
Sep 14, 2015 08:14 AM
