H&R drop, clicking noise from front camber arms?
I just recently installed H&R springs and I haven't driven the car too much because the car still needs alignment, and from my right fender I hear a clicking noise. I think its the camber arm hitting the fender I'm not sure.
I did a search and read thorough the SPC problem they had a while back but its only coming from one side. Do I need bump stops cause I didn't put any in when installing the arms and I do have the right part number I did check.
Should I fix this before getting alignment? or is this something else...
It's now tight, since the alignment tech must have torqued it.
You know it's 120 ft lbs!!
Camber wont raise car.
Skyaddict
13
Nov 8, 2018 07:14 PM
i spoke too soon and the squeaking is a lot less now but i can still hear it on certain roads
