Steering wheel vibration comes and goes
Old 05-21-2010, 09:46 PM
SlateBlue G
SlateBlue G's Avatar
So I have this problem it's just driving me nuts.Speeds 60-70 steering wheel is perfect at times then shakes at times when cruising.I have aftermarket wheels with hub ring and alignment just done with roadforce balance. Any suggestions?
Old 05-21-2010, 09:54 PM
G37Sam
G37Sam's Avatar
Does it only occur under braking or just when cruising?
Old 05-21-2010, 10:11 PM
SlateBlue G
Cruising
Old 05-21-2010, 10:41 PM
Loi
Loi's Avatar
Do you have the right size hub rings? It's suppose to be a snug fit.
Old 05-22-2010, 02:20 PM
SlateBlue G
only thing I can see that is a very small gap after the hub to the end of the wheel.
Old 05-22-2010, 02:34 PM
Mike
Mike's Avatar
Have you had your wheels rebalanced?
Tires don't wear perfectly evenly, and it sounds like it could be a balancing issue.
Old 05-22-2010, 02:44 PM
VossenG37S
VossenG37S's Avatar
I have exact same problem.
Old 05-22-2010, 02:56 PM
Loi
Loi's Avatar
Can't really see any gap int he pics, but I ordered hub rings and they sent me the wrong size, just 1mm too big, and it's causing vibration.
Old 05-22-2010, 03:01 PM
Loi
Loi's Avatar
and yea, I know how you feel when it starts shaking, I would start to think omg is my tires about to blow? or my lugs coming loose and my rims gonna go flying off?!! lol
Old 05-27-2010, 09:51 AM
SlateBlue G
Problem solved.after I drove couple hundred miles after new tires the balance was all wacked out.no vibrations now after new balance
j50ny
07-21-2017 10:46 AM
kavcheung
01-22-2016 02:40 PM
helloandchau
10-06-2015 05:26 PM
xpcgamer
09-07-2015 07:10 PM
Quick Reply: Steering wheel vibration comes and goes
