Max front wheel / size width?
Old Mar 3, 2010 | 02:12 AM
kame_sanjo's Avatar
kame_sanjo
Looking at enkei GTC01 18x8.5 front and 18x10 rear. in this case i would have 245/40 front and 285/35 rear. i was told from a friend that this config. would cause extra understeer and i should do 265/35 front (18x9.0 or 18x9.5).
offsets for the 18x8.5 is 30 or 35, 18x9.5 is 38, and 18x10 is 22.
tryin to figure out what can fit. i know 275/40 fits without turning the wheel with a different brand but i dont know offsets etc.
Old Mar 3, 2010 | 09:38 AM
G37Sam's Avatar
G37Sam
265 in the front on 8.5"? Might be pushing it a bit
Offsets don't affect the fitment of tires
Old Mar 3, 2010 | 04:57 PM
kame_sanjo's Avatar
kame_sanjo
Yea I know. The 265 is going to be on 9.5in width if 265 will fit. And the offset was me wondering about which to get for those wheels.
Old Mar 10, 2010 | 03:07 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Technically the offset will determine where the wheel and tire will be positioned on the car which can lead to rubbing issues. Lower the offset # further out the wheel/tire will sit, larger the offset # further in the pack will sit.
Old Mar 22, 2010 | 10:52 PM
kame_sanjo's Avatar
kame_sanjo
Well I started looking into the enkei pf0, 9.5 at +45 offset, and 265 tires. Then 10.5 rear at +38 offset and 295 tires.
Old Mar 22, 2010 | 10:55 PM
That might work except the rear tire sounds too wide. I have 285 on my 10.5" wide rears. Probably 255 tires in front too. Sounds like they may fit well.
Old Mar 22, 2010 | 11:19 PM
kame_sanjo's Avatar
kame_sanjo
Comin out of the woodwork bb! . Yea a friend said 295 to hold the road more. So can we agree on 255 for front grip? I'm not gonna track a lot so it's more for everyday.
Old Mar 22, 2010 | 11:25 PM
LOL. I told you man, I can help you a little with tire sizes if you have a wheel size and offset.
255 up front. If you aren't tracking it, all 295 tires will do is make you possibly rub the fender, throw your speedometer off a little more, cost more money, make more noise, and be more susceptible to hydroplaning in the rain.
Wait, are these for 18" wheels or 19"?
Old Mar 22, 2010 | 11:32 PM
kame_sanjo's Avatar
kame_sanjo
they are 18". and this wheel offset calculator tells me im losing 12mm on the inside which doesnt seem like much.
Old Mar 22, 2010 | 11:45 PM
Doesn't seem like much, but it may not clear the brakes. Go measure to make sure that you have 12 mm clearance from stock wheels to spare. My calculator says 18"x9.5" front is 17mm closer in to brakes. Going to a smaller diameter wheel, you also have to consider that the inner wheel barrel is going to be closer in to the hub by 1/2" inch because of the smaller wheel radius. Keep this in mind for brake clearance.
For 18" wheels, I'd go 255/45/18 front and 285/40/18 rear. But you still really need to test fit to make sure of clearance.
Old Mar 22, 2010 | 11:56 PM
kame_sanjo's Avatar
kame_sanjo
what kind of tires do you have? nitto doesnt have 255 nt05 and falken doesnt have 285 for azenis
Old Mar 22, 2010 | 11:58 PM
I have 20" wheels. Hankook Ventus V12 III 285/30/20.
Old Mar 22, 2010 | 11:59 PM
kame_sanjo's Avatar
kame_sanjo
ah. im gonna go measure my wheel well space and to the fender lip.
Old Mar 23, 2010 | 12:38 AM
kame_sanjo's Avatar
kame_sanjo
so, the rear is fine with moving out about 1.023 inches and the front will need a spacer to even it out. cant really tell how to measure the inside. feels like i have a couple inches.
Old Mar 24, 2010 | 01:21 AM
kame_sanjo's Avatar
kame_sanjo
comparing bridgestone and falkens specs on tires. i found a 255/40 front and 295/40 rear combo. front loses .5in diameter, gains .5in width. rear gains .25in diameter and 1in width.
