Strut Bar / Sway Bar
Old Mar 3, 2010 | 12:13 AM
  #46
ucla bruin's Avatar
ucla bruin
Originally Posted by stryker2
@ucla bruin: thanks for sharing your impressions. The Eibachs are my next mod.
Interesting to hear you haven't needed a camber kit to keep the alignment to spec. That makes the springs a lot easier to justify, $ wise. Did you buy them from Amplified, or elsewhere and have them installed there?
No problem. I got them from Amplified as well. Give them a call. Tell Lou you were talking about it in the thread with me and you're interested in the Hotchkis and Eibachs.
Good luck.
__________________
Old Mar 3, 2010 | 02:44 PM
  #47
stryker2's Avatar
stryker2
@ucla bruin: I sent Lou a pm. Thanks for the referral. I will mention your name.
Old Mar 3, 2010 | 03:48 PM
  #48
ucla bruin's Avatar
ucla bruin
Not a problem. Let me know if you have trouble getting a hold of him.
__________________
Old Mar 13, 2010 | 05:07 PM
  #49
stryker2's Avatar
stryker2
@ucla bruin: I just got back from seeing Lou at Amplified. I'm having the springs installed on Friday. Thanks for answering my questions. I mentioned that you and sbmwg37s were the ones who recommended his shop to me.
Old Mar 13, 2010 | 05:10 PM
  #50
sbmwg37s's Avatar
sbmwg37s
Nice. If you hate the front fender gap as much as I do, you will love how it looks with eiback springs.
Old Mar 13, 2010 | 05:14 PM
  #51
stryker2's Avatar
stryker2
The front gap does look too large from some angles, I won't miss it. I'm excited to see and experience the change in looks and handling. Amplified is a very nice shop, I was impressed.
Old Mar 13, 2010 | 10:08 PM
  #52
ucla bruin's Avatar
ucla bruin
Not a problem, glad it worked out!
__________________
Old Mar 16, 2010 | 06:58 PM
  #53
stryker2's Avatar
stryker2
While we're on the subject: I've read that adjusting the aim of the headlights might be necessary once the car is lowered. Has this been an issue for anyone? Just curious and wondering how involved it is.
Old Mar 16, 2010 | 09:06 PM
  #54
ucla bruin's Avatar
ucla bruin
Yes. You do. There should be a DIY on how to adjust the headlights. Do a search on "adjust headlights".
__________________
Old Mar 16, 2010 | 10:45 PM
  #55
stryker2's Avatar
stryker2
Will do, thanks for the tip.
Old Mar 16, 2010 | 11:08 PM
  #56
G37Sam's Avatar
G37Sam
With Eibachs you definitely need that done IMO
Old Mar 16, 2010 | 11:54 PM
  #57
oreoleo's Avatar
oreoleo
Completely offtopic, is the front wheel gap compensating the weight distribution? As in, once I put in my KW v3 and get them corner balanced, the rear will have to go down even further than the fronts to get that distribution back?
Thanks
Old Mar 17, 2010 | 02:33 AM
  #58
ucla bruin's Avatar
ucla bruin
I wouldn't be surprised. After corner balance, your ride height may be slightly different on each corner so the diagonal cross corner weights are the same.
If your alignment guy is good, he may ask you to sit in your car while doing the alignment to take into consideration of the driver weight.
__________________
Old Mar 25, 2010 | 06:08 PM
  #59
stryker2's Avatar
stryker2
Eibach prokits are on, just drove the car home from Amplified. Thanks to ucla bruin, sbmwg37s, and everyone else who answered my questions and helped steer me in the right direction. Amplified is a great shop, I can't recommend them highly enough.
I decided to have a rear camber kit installed as well, to be on the safe side. Once the new springs settle in a week or two, I'll be getting an alignment. Looking at the car now with my highly unprofessional eye, it doesn't appear that the front will be within factory specs. There may or may not be a front camber kit in my future, depending how quickly I go through front tires.
The biggest shock to me is how civilized the car still is. The most dramatic change is purely aesthetic - I love the stance with the smaller wheel gaps, particularly in front. On the freeway, the difference in ride quality is almost imperceptible. Around town at low speeds, I did notice an ever-so-faint hum from the front, which I attribute to the slight negative camber. Over bumps and such, it's a little rougher than stock, but nothing I'd describe as tooth-rattling. And of course, handling and cornering are improved significantly. There doesn't seem to be a whole lot of sacrifice required for this mod (other than $).
These observations are after one drive, I'll share more as time goes by and I drive the car under more varied conditions. But I'm very optimistic.
si_driver
Sep 30, 2015 11:46 AM
BurtoN86
Sep 30, 2015 03:32 AM
djdiskino
Sep 29, 2015 07:18 PM
dedmanchan
Sep 24, 2015 11:25 PM
GFTW
Sep 19, 2015 03:52 PM
