Recently changed my brake pads. VERY LOUD NOISE. Please help.
Old Nov 30, 2009 | 06:29 PM
WhiteG37Argen's Avatar
WhiteG37Argen
I recently changed my break pad and shortly after i did so my brakes sqeak/whine very lound but only when the car is in reverse. While i am in drive this problem does not occur. It is only when i am backing up and braking. It is very loud. Thank for your help/
Old Nov 30, 2009 | 07:02 PM
chamelieon's Avatar
chamelieon
rotor surfaces as well as brake pad surfaces are all flat. shouldnt matter what direction they spin, should make no difference either way.
i highly doubt the noise is coming from all four corners of the car when you are going into reverse but you didnt say if you did the fronts/rear or all four. and you changed rotors as well?
sounds like you have an automatic transmission, but i dont see how that can make any difference.
have you jacked up the car, taken the wheels off and inspected that everything was installed correctly and no brake parts are touching?
Old Nov 30, 2009 | 07:10 PM
G37Sam's Avatar
G37Sam
Brake bedding in, look it up
Here's a thread discussing the issue recently: https://www.myg37.com/forums/g37-sed...ise-maybe.html
Old Nov 30, 2009 | 07:19 PM
Need to be bedded in.
Tech Tips: Performance Street break-in procedure - RacingBrake.com
Tech Tips: Re-bedding procedure - RacingBrake.com
Old Nov 30, 2009 | 07:37 PM
wakeboardr116's Avatar
wakeboardr116
The master has spoken. thread closed.
SBG37
Mar 12, 2021 03:16 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
joeposter
Sep 8, 2015 04:36 PM
Digilog
Aug 17, 2015 03:54 PM
zero260
Aug 12, 2015 10:02 AM
