20'' Vossen wheels and Eibach springs on G37x AWD Coupe
I am planning to install 20'' VVS078 with Eibach springs.
My questions are...
1. Which one should I install first between the wheels and the springs?
2. Would 20*9 wheels work on my AWD coupe?
3. Should I also put camber kit? ( I heard that camber kit is a must-item with 20'', but not with 19'')
I have've been searching them, but could not get the result with AWD coupe.
Thank you for your time!!
My questions are...
1. Doesn't really matter. Are you doing the installs your self? If so I'd do the springs first since you will have the wheels off then once your done put the new wheels on.
2. Everything with wheels depends on the offset.
3. If you want your tires to last, then yes i'd get a camber kit. Also I don't know what kind of affect it would have on the AWD system without one.
I don't really know for sure on the AWD. But i know it has been discussed around here before. You should be able to find it searching. If not i'm sure someone who knows what offsets work well for AWD will chime in.
It doesnt matter with eibachs
Offset please
The size of the rim has nothing to do with the camber
You shouldnt need camber with the Eibach lift kit
Offset please
Im not sure AWD would require camber kit anymore then non-AWD would, especially only running eibach.
I have camber kit front and back with eibach, not out of necessity but because I hate the look of excessive negative camber... and I plan to go a little lower in the future, so I just got it over with while I had to time to do the install.
Curious why you got AWD if your dropping and putting 20's on? You going to be putting stock suspension and wheels on in the winter?
Hey I don't have an AWD Coupe but I do have an AWD sedan and is lowered on eibach springs and have 20" wheels.
1. It doesn't matter if you install the springs first or the rims first.
2. 20x9.0 up to +30 which I'm running. The coupe is wider so maybe you can use a lower offset ( +30 or less)
3. It's up to you to put a Camber kit with eibach springs. Your probably going to have 2degrees of negative camber which doesn't hurt that much. Just make sure to get an alignment about 300-500 miles after you drive on the springs.
Your cars AWD system won't be affected in anyway with negative camber. Just make sure you get hubcentric rings with your wheels if don't want any vibration after replacing your wheels. Good luck and if you need anymore info about AWD with wheels and drop I'll answer any questions you have.
Sorry if I misspell anything I'm typing from a iPhone
the eibachs for the AWD coupe lower it significantly more than the eibachs for the sport. The drop rates are 1.5 in rear and 1.9 in front (and they settle a bit too). I ended up with about a half inch wheel gap after they settled and with no one in the car. Camber kit for the fronts for me was needed....very badly and the rears could use one as well, but not as bad as fronts. The rears I have the toe in spec and the camber is roughly -2.4 or something. The problem is there are no aftermarket rear camber kits for the AWD coupe yet.
I had 20x9 tires with I think was 38 offset, I may be wrong though....
hey triple_x got any pics of ur car lowered, i got the same as you and i am looking to lower mine as well, you wouldnt happen to have a link to the site you bought ur springs from do you? that would be very much appreciated if you did
Help please
I been searching and I can't find any answers. I just ordered a set of 20x9+20 all around for my AWD q60 coupe. My question is what tire size should I get? What extra work would I have to do to make it fit?
If anyone can help me I would appreciate it. Also I'm lowered on BC COILOVERS
what made you go with 20mm?
i am also an x and looking for 20x9 but dont know what offset to choose
To be honest I spoke with the dealer I got my wheels from and that's what they recommend. I'm afraid it's going to be too aggressive but I kno o would have to do slight extra work to make it fit
