Toe bolt kit needs to be install?
Old May 18, 2009 | 08:23 PM
JDM's Avatar
JDM
when the shop installed my coils and rear camber arms, they said i didnt need to install the toe bolts, which got me wondering if this was true or not or they just forgot and got lazy? inputs? thanks!
Old May 18, 2009 | 09:02 PM
oOmikeyboy's Avatar
oOmikeyboy
My shop thought that they didn't need to install it.. but he had issues keeping toe and camber in spec without the bolts. Did they charge you for the camber kit install? Might as well get them to install the bolts as they were doing it.
Old May 18, 2009 | 09:24 PM
HamstersG's Avatar
HamstersG
Agree. You might need it one day and it does no harm to put it in.
Old May 18, 2009 | 10:08 PM
ReddieG37's Avatar
ReddieG37
I think the camber and toe affect each other. So if camber is within specs, it might be impossible to put the toe in spec etc.. unless u run more negative camber. It'll probably be better to get both installed. But this all depends on how low your drop is.
Old May 18, 2009 | 11:16 PM
JDM's Avatar
JDM
would it be an issue to get my car aligh if i didnt get the toes in?
im not riding that low but i have terrible camber in 1 of my rear wheels
Old May 18, 2009 | 11:18 PM
ReddieG37's Avatar
ReddieG37
what are you dropped on?
Old May 18, 2009 | 11:19 PM
JDM's Avatar
JDM
here's pix of the bad camber in the rear driver side, this was a few days ago, it has gotton worst, i will get an alighment this friday
Old May 18, 2009 | 11:20 PM
JDM's Avatar
JDM
coilovers
Old May 18, 2009 | 11:32 PM
ReddieG37's Avatar
ReddieG37
seems close.. i think you can get it "within specs" but barely. but id get the toe bolts installed before getting it aligned.
Old May 19, 2009 | 12:06 AM
JDM's Avatar
JDM
can the alignment shop put the toe bolts on themselves?
G's
Nov 5, 2023 12:01 PM
Ipp391
Aug 28, 2015 09:27 AM
kavcheung
Intake and Exhaust
Aug 25, 2015 01:07 AM
cparise
Aug 19, 2015 01:51 PM
