Need quick helppppp
Old May 11, 2009 | 03:57 PM
nostalgia85's Avatar
nostalgia85
Need quick helppppp
my friend offers this to me he had this on 350z 07 should i take it? im not into sus and rims. spring will perfectly fit on g37s?
please gimme an advice
volks GTS mercury silver
Rims
front 19-9.5 +17
rear 19-10.5 +18
Tire
nitto invo
front 255/35/19
rear 285/35/19
spiein gf210- 1inch front 1.2 rear
everything is 1800 bucks
what do u think?
http://img219.imageshack.us/img219/2373/p5110033.jpg
http://img219.imageshack.us/img219/8360/p5110031j.jpg
http://img219.imageshack.us/img219/7278/p5110032y.jpg
Old May 11, 2009 | 04:01 PM
aliiin's Avatar
aliiin
BMW Defector
offsets look too aggressive... why don't you test fit them?
Old May 11, 2009 | 04:06 PM
Heat's Avatar
Heat
Not a bad price. I highly doubt the springs will work. The tires are different circumfrences. I think the 350z's are stock like that if I remember.
Old May 11, 2009 | 04:13 PM
nostalgia85
G37 OEM Wheels Specs
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
G37
non sport
Front & Rear 18x8 +43mm offset
Commonly used after-market offsets:
Front width: 8.5" +30-35mm offset
Rear width: 9.5" +30-35mm offset
this is what i found
so there is no way this will fit?
Old May 11, 2009 | 04:18 PM
Heat's Avatar
Heat
I would do a test fit and see how you like it.
Old May 11, 2009 | 04:49 PM
xyz's Avatar
xyz
I think fronts high +20s and rears low +30s are the max offsets for our cars if you have the S (to clear the akebono).
Old May 11, 2009 | 04:55 PM
nostalgia85
so if i put 3-5mm spacer would it work?
cuz i dont wanna order spacer and test fit
Old May 11, 2009 | 05:02 PM
SOLISIMO's Avatar
SOLISIMO
again no, Im running a 25 offset with a 5mm spacer and thats agressive and I rub.
Old May 11, 2009 | 05:04 PM
nostalgia85
ah ****..our car sucks
Old May 11, 2009 | 05:06 PM
Loi's Avatar
Loi
I think it's too agressive, you wheels would be outside of your fenders by an inch or so.
Old May 11, 2009 | 06:51 PM
GiGGaplease's Avatar
GiGGaplease
so, your rims are +30 rear then. high 20's offset will work for the rear. low 20's will work for the front.
if your car isnt rubbing, you have the wrong offset, ill advise you to go get a lower offset.
Old May 11, 2009 | 07:08 PM
SOLISIMO's Avatar
SOLISIMO
Im rubbing on H&Rs thats why
Old May 11, 2009 | 07:15 PM
GiGGaplease
oh, i wasnt talking about you. saw your negative camber in the rear, **** is sick.
Old May 11, 2009 | 07:51 PM
jnguyen's Avatar
jnguyen
we should trade out brakes. Your sports brake for my Non sports brake straight up and i pay shipping for both and then you dont have to worry about clearing BBK haaha
mahadeod
Oct 6, 2015 01:02 PM
Chappedj
Sep 28, 2015 03:20 PM
czirrfb
Sep 16, 2015 04:09 PM
